Ambient occlusion issue
Posted By Walvince 5 Years Ago
Walvince
Walvince
Posts: 99, Visits: 972
Hi,
I noticed the below problem, it occurs when an object is about to leave or enter the  camera range.
You can see here what happens near the floor, and it's doing the same thing for each step of the stair if the camera keeps going up. :crazy:
Do you have the same problem ? I tried to change some ambient occlusion and other visuals parameters but in vain.
https://forum.reallusion.com/uploads/images/896e3bbe-a80a-412b-b7b2-1e6c.gif
3DChick
3DChick
Last Active: 3 Weeks Ago
Posts: 411, Visits: 1.9K
That's very odd. Could it be a shadow flicker issue?
____________________________________________
Life-long learner and having waaaay too much fun with iClone! Youtube Channel: 3DChick
Book Covers: www.significantcover.com Largely Unfinished Fiction: www.nemontgomery.com
Walvince
Walvince
I don't think so, I tried to switch it on/off and change the resolution but it wasn't better.
It's not only happening since 7.9, I already had this problem on previous versions, but that was fine as long as I hadn't a camera shot filming stairs :P
3DChick
3DChick
Sadly that was my only idea. I'll try to replicate it when I get home this afternoon... It's not something I've encountered...
Walvince
Walvince
Thanks ;)
That's strange, I tried on a completely different computer with a fresh install of iclone and the issue is exactly the same :doze:
If some want to test, here is a small test project : https://www.mediafire.com/file/m4jhwafthund8c4/Ambient_Occlusion_Test.iProject/file
Posts: 5.3K, Visits: 16.8K
Wow, quite repeatable. I seams like camera clips vertical AO planes at the bottom regardless of lights/shadows? (I do not know how it works)
You should definitely submit an FT issue. For now I suppose only AO maps are safe to use.
3DChick
3DChick
4u2ges got to it before I did--and wow, so interesting! I'll still try when I get back to my Windows machine...
3DChick
3DChick
Ok, so I got it too, almost made my eyes bug out in the preview, but it's way less noticeable in the final render. Here's that:
I can't upload a screen cap of the preview because my laptop bit the dust last week, and I don't have screen capture stuff reinstalled yet. But yes, it was absolutely there no matter what settings I changed, tho.
Very odd.
Posts: 15.8K, Visits: 31.4K
I have no luck posting; this is the third time...:crazy: And, I'm getting tired...:doze:
Anyway, the reason that you see what you see is that one of the surfaces that is responsible for generating the AO moves out of view when the camera moves up.
What should happen is for the AO algorithm to consider an area outside the current view as well so that a surface that has moved out of view still "counts" in the calculation.
You can see the effect of this idea when you add an image layer that creates a border around the visible area. The invisible surface still "counts" in this case which improves the visual effect.
Walvince
Walvince
Thank you for your feedbacks ! I just submitted an FT.
I never used AO maps but it's a good idea, I'll test that and see if it can do some magic :)
