Can you copy a sprite from one G2 character to another
Posted By VocalPics 4 Years Ago
VocalPics
VocalPics
Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)Veteran Member (590 reputation)
Posts: 24, Visits: 134
I am creating a female character using an outfit from the G2 body composer kit 2. I need to have a long sleeve jacket which I can turn completely black. Initially the upper2_02 jacket looked ideal... but unfortunately it has a cleavage which is not appropriate for the animated character I need to create!
I then noticed that Upper_2 01 jacket didn't have a cleavage, but it has a neck scarf which I want to change for a normal neck. I can see that this neck scarf sprite replaces the normal default neck. All I want to do is remove the neck scarf and replace it with a default flesh coloured neck without having to create the actual artwork myself. I have managed to delete the neck scarf, but cannot work out how to replace it with the standard neck? I hope it is possible.
It would be a life saver if someone could provide me with instructions on how to do it step by step as I am very new to this program.
