codyvbrown
codyvbrown
Visits: 61
thanks all! I'll give this another pass with mesh smoothing and editing the texture file in photoshop.
Posts: 5.3K,
Visits: 16.8K
Kelleytoons (5/11/2021) Mr. G has you well taken care of (but I have to comment and ask - "Just how did you get a picture of me?" :>).No, no, I was looking in the mirror :w00t:
michaelrbarton
michaelrbarton
Visits: 11.2K
I used edit mesh on the stomach. My settings were radius 9 and falloff 25.00.
michaelrbarton
michaelrbarton
Visits: 11.2K
You have to activate skin editor and go to strength panel for body and turn it down to 0. Then you can use the heavy body type and further adjust the stomach. This is the best I could do. You can also go to edit mesh mode and pull the crease out of the stomach.
Visits: 22.1K
Posts: 5.3K,
Visits: 16.8K
That is a texture confusing you. Just apply a smooth brush over the center line and then if you have a "Realistic Human Skin" load Male Heavy skin profile. If still not satisfied, Photoshop the texture, smoothing/blending center abs outline with the rest of the belly.
codyvbrown
codyvbrown
Visits: 61
4u2ges (5/10/2021) You can always *type* a negative value in the value box to go down from 0... or use sculpt brushes (inflate first and then smooth) to flatten it in Edit Mesh mode.
thanks, I tried that but even when I put in a ridiculous number (like -200) and rebake the material still shows the line. do you know how I can get rid of the line?
Posts: 5.3K,
Visits: 16.8K
codyvbrown
codyvbrown
Visits: 61
Kelleytoons (5/10/2021) The only thing I would mention is you can "bake" any morph into the character and then apply it again. So there is no limit to the amount of any particular morph.
I would play with this myself but I'm a bit too inebriated. But I suspect you can get what you want by careful adjustments (don't forget using the "pregnant" morph).thanks Kellytoons! I tried this, and I could be doing something wrong here, but that setting is already set at 0. so I've been unable to re bake it when it's there. the default 0 on the ab line seems to be already sunken so can't flatten it. but maybe I'm missing something? thx again for help.
Visits: 22.1K
The only thing I would mention is you can "bake" any morph into the character and then apply it again. So there is no limit to the amount of any particular morph. I would play with this myself but I'm a bit too inebriated. But I suspect you can get what you want by careful adjustments (don't forget using the "pregnant" morph).
