Path between trees :)
Posted By Amper Sand 4 Years Ago
Amper Sand
Amper Sand
Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)
Posts: 731, Visits: 5.2K
Does anybody have an idea about a (relative) confortable way to create a path between trees? :) :)
The main problem to me is the fact that path points got hidden by trees' leafs and, unlike props, I cannot preview trees as wireframe or X-ray, neither to adjust opacity. I tried to do it "from below", but quite the same nightmare.
I was thinking to first create the path and only after that to plant the trees, but would be the same problem if/when I will have to adjust the path later, so I would be back to "square one" with my problem.
Thanks!
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
gordryd
gordryd
Posts: 730, Visits: 8.0K
You could try scaling the trees down while you create the path.  Then scale back up after the path is complete?
Last Active: 12 hours ago
Posts: 8.2K, Visits: 62.6K
Look up from the bottom when making your path. If the trees are on a terrain, you probably can hide the terrain.
https://forum.reallusion.com/uploads/images/2d0f28b6-00b1-4f03-8cf1-c0df.jpg
mark
mark
Posts: 4.9K, Visits: 16.7K
I'll assume you are using the ALT-RIGHT MOUSE BUTTON  combo to move around the screen?
PROMO-BACK2
Amper Sand
Amper Sand
Thank you all for help - I just made few tries :)
Eventually, I think the most convenient approach was a combination between part of @Rampa's advice (hide the terrain) plus hiding/showing groups of trees around the place where you want to set a new point of the path. I cannot say I was doing it at a light speed, but definitely not at a snail pace either. Got a decent result, to be honest, once I will have it a bit polished I will show you.
@gordryd I thought initially your idea is brillliant in its simplicity - and it would be if iClone would allow directional scaling for trees: I mean, shrink them vertically, set the path points, then scale the trees back. Well, it seems trees can be scaled ONLY on all three direction simultaneously, thus the whole "forest" shrinks or grows accordingly (X-Y)
@mark yes, I'm using also the Alt+RightMouse combination, but the problem for me was not navigation, but visibility - path points are really hiding behind leaves, branches, bushes and trunks :)))
mark
mark
Maybe put a dummy/placeholder object at the tree positions to give you an idea where the trees are?
PROMO-BACK2
