sencorpx
sencorpx
Visits: 69
Wondering if anyone else has had this issue? Thanks in advance.
All the updates are being blocked. Iclone CC3 3DX IRay Smart gallery Even when run as administrator or set to to allow. It still blocks everything
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
my friend just had his laptop go crunk and lock him out after the last windows 10 update .... turns out part of the problem is a bug with bitlocker. I'd do a little investigating on the last windows update and any bugs that came with it. His problem got worse when he uninstalled his anti-virus program while troubleshooting. - so the security and bitlocker seem to be related. - not saying this is the problem, but it's the first place I'd check.
SCE
Visits: 926
Yeah I tried a few times to get past Norton Antivirus and it didn't work. I can't update anything.
Last Active: 9 minutes ago
sencorpx (4/12/2021) Wondering if anyone else has had this issue? Thanks in advance.
All the updates are being blocked. Iclone CC3 3DX IRay Smart gallery Even when run as administrator or set to to allow. It still blocks everything Are you using Windows 10 and the included Windows Security software? If so I haven't found any problems updating so I would check to make sure you have your anti-virus definitions updated to the latest (run Windows Update to be sure). This may resolve the problem for you.
Amper Sand
Amper Sand
Visits: 5.2K
No problem here, upgrade went smooth from RL Hub: Edition: Windows 10 Pro Version: 20H2 OS build: 19042.906 Experience: Windows Feature Experience Pack 120.2212.551.0 No additional antivirus installed.
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
DS-Waqas
DS-Waqas
Visits: 284
Yup, I can't update anything! Norton keep blocking everything even after I've disabled it. Even better I cannot even open Iclone now!
planetstardragon
planetstardragon
Posts: 11.5K,
Visits: 45.9K
They are aware of the false positives, RL issued a special update for the kaspersky false flags - since RL software interacts with each other, it's easy to false positive it as a threat..... you can find that update here - hopefully it will work with norton too. good luck! https://forum.reallusion.com/479677/Whats-New-in-Smart-Gallery-12
rrajiah
rrajiah
Visits: 31
Hello all
Had a similar issue for weeks and couldn't update anything as being blocked by Norton Security. I'm using Windows 11 and updated to the latest available version. Today, I finally managed to update Real Illusion Hub as well CC 4 + IC 8 to the latest versions by simply disabling Norton Auto Protect and Norton Firewall for 15 minutes. No further issues.
Hope that helps !
