InstaLOD hair with Prime Hairstyles and CC4... disaster
Posted By bennett_027069 4 Years Ago
bennett_027069
bennett_027069
Senior Member (283 reputation)Senior Member (283 reputation)Senior Member (283 reputation)Senior Member (283 reputation)Senior Member (283 reputation)Senior Member (283 reputation)Senior Member (283 reputation)Senior Member (283 reputation)Senior Member (283 reputation)
Posts: 4, Visits: 46
Hi everyone
I'm using FBX export with the InstaLOD default setting, keeping the original avatar as LOD0 and making LOD1 and LOD2 from InstaLOD. The skin and clothes output fine but the hair is a total disaster - see the attached image. It's nothing to do with the import into Unity - these errors are baked into the textures.
This is latest CC 3.4.
Anyone have any idea what I'm doing wrong? Or having the same issues?
https://forum.reallusion.com/uploads/images/d6903bba-7d47-4703-b468-44ab.png
Melvin (RL)
Melvin (RL)
Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)
Group: Moderators
Posts: 83, Visits: 1.7K
Hi bennett_027069
This problem is caused by opacity.
LOD can't handle the mesh have opacity, so here is the workaround.
Use edit mesh function in CC to hide the mesh which have opacity texture. ex. Scalp , Brows base.
After do that workaround this issue should be solve.
https://forum.reallusion.com/uploads/images/803d9465-57f8-4088-b22f-2a8f.gif
bennett_027069
bennett_027069
So, I followed this step, which helps with the fringes, but the look of these models is still pretty disastrous compared to what's in the docs. Basically everything about this is fine for distant LODs except the hair which is nothing like the original. I'd appreciate any tips.
  https://forum.reallusion.com/uploads/images/79b380bd-123a-4e66-82e9-aeea.png
bennett_027069
bennett_027069
Having done more experiments, this isn't limited to a Unity thing. The instaLOD is getting the wrong color for the prime hairstyles.
Necka
Necka
Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)Veteran Member (569 reputation)
Posts: 62, Visits: 407
Same issue here. Merged material isn't working fine with new Hair/Brows/Beard, just noticed that I didn't test before
tantrum
tantrum
Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)Senior Member (271 reputation)
Posts: 28, Visits: 502
Sounds like an extension of this issue I reported in March, although my example was focused on just the brows at the time.
In May you'll see there is a comment about the causes being to do with how InstaLOD was making the textures:
Smart hair merged materials builds wrong diffuse map - FeedBack Tracker (reallusion.com)
Anonymous
Anonymous
New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)New Member (2 reputation)
Posts: 2, Visits: 16
Has anyone found a solution for this?
kelbyvp
kelbyvp
Veteran Member (629 reputation)Veteran Member (629 reputation)Veteran Member (629 reputation)Veteran Member (629 reputation)Veteran Member (629 reputation)Veteran Member (629 reputation)Veteran Member (629 reputation)Veteran Member (629 reputation)Veteran Member (629 reputation)
Posts: 50, Visits: 539
I gave up on InstaLOD and just create LODs in Unreal.
kelbyvp
kelbyvp
I gave up on InstaLODs and just create LODS in Unreal.
Anonymous
Anonymous
kelbyvp (12/31/2021)
Oh actually I found a solution. Hide the scalp layer of hair and everything seems to render way better.
