InstaLOD hair with Prime Hairstyles and CC4... disaster
https://forum.reallusion.com/Topic478454.aspx
Print Topic | Close Window
By bennett_027069 - 4 Years Ago
Hi everyone
I'm using FBX export with the InstaLOD default setting, keeping the original avatar as LOD0 and making LOD1 and LOD2 from InstaLOD. The skin and clothes output fine but the hair is a total disaster - see the attached image. It's nothing to do with the import into Unity - these errors are baked into the textures.
This is latest CC 3.4.
Anyone have any idea what I'm doing wrong? Or having the same issues?
https://forum.reallusion.com/uploads/images/d6903bba-7d47-4703-b468-44ab.png
By Melvin_RL - 4 Years Ago
Hi bennett_027069
This problem is caused by opacity.
LOD can't handle the mesh have opacity, so here is the workaround.
Use edit mesh function in CC to hide the mesh which have opacity texture. ex. Scalp , Brows base.
After do that workaround this issue should be solve.
https://forum.reallusion.com/uploads/images/803d9465-57f8-4088-b22f-2a8f.gif
So, I followed this step, which helps with the fringes, but the look of these models is still pretty disastrous compared to what's in the docs. Basically everything about this is fine for distant LODs except the hair which is nothing like the original. I'd appreciate any tips.
  https://forum.reallusion.com/uploads/images/79b380bd-123a-4e66-82e9-aeea.png
Having done more experiments, this isn't limited to a Unity thing. The instaLOD is getting the wrong color for the prime hairstyles.
By Necka - 4 Years Ago
Same issue here. Merged material isn't working fine with new Hair/Brows/Beard, just noticed that I didn't test before
By tantrum - 4 Years Ago
Sounds like an extension of this issue I reported in March, although my example was focused on just the brows at the time.
In May you'll see there is a comment about the causes being to do with how InstaLOD was making the textures:
Smart hair merged materials builds wrong diffuse map - FeedBack Tracker (reallusion.com)
By Anonymous - 4 Years Ago
Has anyone found a solution for this?
By kelbyvp - 4 Years Ago
I gave up on InstaLOD and just create LODs in Unreal.
I gave up on InstaLODs and just create LODS in Unreal.
kelbyvp (12/31/2021)
Oh actually I found a solution. Hide the scalp layer of hair and everything seems to render way better.
