Cary B
Cary B
Visits: 3.8K
I've never had an Iphone before I recently bought one to use with Live Face Iclone mocap. I've heard in tutorials that the mocap works best when the Iphone is connected to the PC directly through a cable. I see there are different ways to do this...through Itunes or through a personal hotspot...maybe other ways as well. Appreciate if anyone can let me know the best way to connect the Iphone to Windows PC for best mocap results. Thanks!
gordryd
gordryd
Visits: 8.1K
I just use the provided iPhone charging cable and plug it into a USB port on my PC. Never had a problem. Just have to make sure you type ":999" at the end of the IP address in MotionLive. You don't need iTunes (probably don't want it running in the background anyway while you are doing face capture)
charly Rama
charly Rama
Posts: 1.9K,
Visits: 17.3K
I confirm Gordryd. I've never needed another cable for my connection to the pc. The simple usb cable works. for my part, itunes must be opened every time I connect my iphone if not it doesn't work. I activate the "share connection" , and Iclone recognize my IP without typing it.
Visits: 22.1K
I use an ethernet cable setup -- works better (for me) than the USB one and just far easier to setup (plus I never have a lag that I do notice when I use USB). But whatever works for you.
Cary B
Cary B
Visits: 3.8K
Mike, thanks, that's my ultimate goal, to reduce the lag time I currently experience. But forgive my ignorance...you're talking about some special cable adaptor to go from the lightning connector to the PC ethernet port, right? Something like this ethernet lan ? And do you think this ethernet connector would work without a sim card? My wifi connection works without a sim card.
Visits: 22.1K
That's not the one I use but, yes, that's the kind of thing that works. I don't know why you would need a sim card - I even turn on the iPhone to airplane mode when I run the ethernet adapter (so it's not even capable of making or receiving phone calls). That's really the only way it works.
Cary B
Cary B
Visits: 3.8K
Thanks!
