Eric C (RL)
Eric C (RL)
Visits: 5.2K
charly Rama (3/24/2021)
Hi, I tried to create a Feed back tracker but there's no ref for version 7.9 yet My problem is every audio I use, the acculips says this and I can't apply the animation Hi Charly,
Thanks for report! We fixed it and now you can submit 7.9 Feedback Tracker.
charly Rama
charly Rama
Last Active: 42 minutes ago
Posts: 1.9K,
Visits: 16.9K
Bassline303 (3/24/2021) Charly, I know that ToyStoryLab had the same issue and it had to do with his Audio Codec.
Ah, interesting Bassline, Could you tell me what did you do with his sound card ?
lianchiu
lianchiu
Visits: 1.5K
charly Rama (3/25/2021)
Ah, interesting Bassline, Could you tell me what did you do with his sound card ? it's not a issue or defect Follow this use Align Select to Wave Area (Select words align to audio wave) 1:18 Transcription Adjustments & Alignment
charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.9K
Did you met the problem that you afirm it's not issue ? I can not come to this step you show to align to audio wave. I can't because of this error message. I can't select words because there's no showed words to align. Look at the capture screen I posted
3 Years Ago by
charly Rama
lianchiu
lianchiu
Visits: 1.5K
charly Rama (3/25/2021) Did you met the problem that you afirm it's not issue ?
I can not come to this step you show to align to audio wave. I can't because of this error message. I can't select words because there's no showed words to align. Look at the capture screen I postedProvide AUDIO to FT I Will Check it out. you can post in Private comment
charly Rama
charly Rama
Posts: 1.9K,
Visits: 16.9K
Thank you so much Lianchiu. I fixed it. The problem was from my soundcard. On Iclone I've selected my external sound card to record the audio. But at my system, the default input soundcard was the build one with the motherboard. I changed the setting to have THE SAME SOUNDCARD and everything work fine now. Once again, thank you for your help proposition, cheers
3 Years Ago by
charly Rama
lianchiu
lianchiu
Visits: 1.5K
charly Rama (3/25/2021) Thank you so much Lianchiu. I fixed it. The problem was from my soundcard.
Once again, thank you for your help proposition, cheersGot it I am glad that you are able to use it. and enjoy IC7.9
Last Active: 3 hours ago
Posts: 15.7K,
Visits: 30.6K
I have a problem with accessing the new Hair content in Content Manager. It partially works, but when I click on Style, iClone gets stuck. It is fine in Smart Gallery. I already applied the provided patch. As I have other issues as well, I wonder if I should just completely uninstall and reinstall iClone as well as CC.
joel.lovell
joel.lovell
Visits: 553
Same issue for me about the two free projects, even after refresh.
3 Years Ago by
joel.lovell
mr_vidius
mr_vidius
Visits: 6.1K
animagic (3/24/2021)
I am unable to access the two new free character projects. It says Free, and if I click on either one I am directed to the Smart Gallery. There is a Free content section there, but I already updated that without success. Update: I had to actually do a manual refresh for the new projects to show up as updates. interesting. i'm very surprised RL does not have a content pack made for just such a problem. personally, i think this is absurd to continue to go thru such a hassle for 2 projects. i tried your suggestion. epic failure. i did notice that when smart gallery is doing whatever it's supposed to do, but failing. the thumb nails flickered for awhile. and when it stopped doing that. nothing. still no projects. how ever, the same issue is with CC too. i was able to install something i purchased for both. and it installed perfectly.
