Can't export FBX - FBX export failed, with no error explanation
Posted By mrtobycook 5 Years Ago
mrtobycook
mrtobycook
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 425, Visits: 2.7K
Hi all,
I'm getting frequent "FBX EXPORT FAILED" messages, for lots of different models, in Character Creator.
As an example, I open Character Creator, open the SkinGen_Makeup example project, export as FBX clothed character then choose the Unreal profile, and it starts working then says "Fbx export failed" with no explanation. If I quit Character Creator then restart, sometimes that fixes it (!!!!!). Sometimes it doesn't. So frustrated. :-)
Official support hjasn't been able to help so far, I think they are super busy. Took two days then I got the advice to make sure I have enough room in my temp folder. I have 2 terabytes available, so that's not it :-)  Anyone know why this is happening? And so randomly?
BTW I've never had these issues before. I have full pipeline version and 3dxchange etc so it's not a limitation of a trial or because I don't have Pipeline etc. And its the default characters I'm seeing the issue on, so it can't be export licenses etc. It's WEIRD. :-)
toby
https://forum.reallusion.com/uploads/images/d11fc97b-7387-4f19-bb1e-0785.png
virtualfilmer.com | youtube
Posts: 23.1K, Visits: 36.6K
mrtobycook (3/6/2021)
By default the Temp folder is stored on your C: drive. Do you have 2 Terabytes free on the C: drive or in total? Nowadays its common to have a small SSD C: drive with the OS on it and then a larger D: data drive. Do check that the drive where your Temp folder is located has plenty of free space. Even if you installed Character Creator on a large drive with 2TB of space the temp folder may still be located on a drive that is low in space.
mrtobycook
mrtobycook
Thanks Peter, sorry yes I meant that it is on a drive that has 2tb of free space (not my system drive)
That doesn't seem to be the cause unfortunately. Any other ideas? I wish it showed an error message or that there was a log of all errors inside iClone that I could read! :-) Would really solve so many problems
jerome.dipietro
jerome.dipietro
Posts: 91, Visits: 1.1K
I was getting this problem because my save file path was too long. Make sure you're not saving into a deeply nested folder or with a file name that's too long.
Unity Virtual Reality Developer
mrtobycook
mrtobycook
Wow!! That's the answer! thanks so much!
jerome.dipietro
jerome.dipietro
I did post this to the FeedbackTracker quite a few months ago when I worked out what the problem was. Hopefully it'll eventually be added as a more informative error message in some future version :)
Nebula480
Nebula480
Posts: 41, Visits: 376
This solved it. Thank you.
