Character creation with a G3 template - Can't select the hand bone to replace/add sprite.
Posted By wezzley 4 Years Ago
Character creation with a G3 template - Can't select the hand bone to...
wezzley
wezzley
Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)Senior Member (285 reputation)
Posts: 18, Visits: 74
Hi! Thanks for any help....I'm using CA4 pipeline, I'm trying to follow this video at 7:40 - https://www.youtube.com/watch?v=kN-mKg5KlmM  He selects and bone and adds the new sprite.....but when I click the hand bone it won't go blue and there is no option to add the new sprite. All other bones have performed as per the video...ie go blue when I click and the '+' option appears to replace the sprite.
Also the hand is not in the arm layer like his....maybe that's something to do with it. Can anyone help, Please I'm begging you...I've spent hours trying to add the hands!!! Thank you so much in advance animator friends
Threaded View
Threaded View
Forum Post Character creation with a G3 template - Can't select the hand bone to... By wezzley ( 4 Years Ago )
Forum Post Use the Layer Manager to select the bone. Then click the Sprite Editor... By vepop ( 4 Years Ago )
Forum Post Hi vepop - thanks for your reply! - I really really appreciate it.... By wezzley ( 4 Years Ago )
Forum Post Sorry .. not sure what you meant by 'bind and stretch' problem. By vepop ( 4 Years Ago )
Forum Post Hi Vepop - again thank you so much for engaging with me. I will attach... By wezzley ( 4 Years Ago )
Forum Post Watch these tuts and see how a character is assembled and correct... By vepop ( 4 Years Ago )
Forum Post Hi, thanks very much for that link, I will definitely watch it but at... By wezzley ( 4 Years Ago )
Forum Post From the screenshot, I see that your character is not properly... By vepop ( 4 Years Ago )
Forum Post Hi again, thanks. When you say not properly prepared I'm guessing you... By wezzley ( 4 Years Ago )
Forum Post I believe the problem you're having is because of the character not... By vepop ( 4 Years Ago )
Forum Post I have had this same issue several times so I sympathize with you. I... By russellearlsmith ( 4 Years Ago )
Forum Post @russellearlsmith If he would share his project file with me, I surely... By vepop ( 4 Years Ago )
Forum Post Hi Vepop - I have spent some hours preparing the body parts Exactly as... By wezzley ( 4 Years Ago )
Forum Post Hi @ russellearlsmith it is very good to connect with you. Sorry to... By wezzley ( 4 Years Ago )
Forum Post Hi Wessley, The rounded ends is just to give the idea that a certain... By vepop ( 4 Years Ago )
Forum Post Hi vepop - yes my sprites are overlapping...the problem is still there... By wezzley ( 4 Years Ago )
Forum Post Did I shout? Nope. Just to highlight that there is NO PROBLEM on my... By vepop ( 4 Years Ago )
Forum Post Here is a link which might help you:-... By vepop ( 4 Years Ago )
Forum Post Hi thanks for the link. I have checked this link already - you seem to... By wezzley ( 4 Years Ago )
Forum Post If you don't mind sharing the project file with me. I will see... By vepop ( 4 Years Ago )
Forum Post wow thanks vepop, I really appreciate your offer to take a look! I... By wezzley ( 4 Years Ago )
Forum Post . . . The Head sub-folder should not be in the RL_Image folder.... By vepop ( 4 Years Ago )
Forum Post Hi vepop, thanks for this detailed reply. I see you are using a 3rd... By wezzley ( 4 Years Ago )
Forum Post [quote][b]wezzley (3/11/2021)[/b][hr]Hi vepop, thanks for this... By Peter (RL) ( 4 Years Ago )
Forum Post Hi Peter, The bind option is not available in my CA4 too. Strangely,... By vepop ( 4 Years Ago )
Forum Post [quote][b]vepop (3/11/2021)[/b][hr]Hi Peter, The bind option is not... By Peter (RL) ( 4 Years Ago )
Forum Post Hi wezzley, If the character is done properly, there shouldn't be any... By vepop ( 4 Years Ago )
Forum Post If you don't mind sharing the project file with me. I will see what... By vepop ( 4 Years Ago )
