opening livelink plugin from iclone causes crash
Posted By davidmaximo 3 Years Ago
davidmaximo
davidmaximo
Veteran Member (734 reputation)Veteran Member (734 reputation)Veteran Member (734 reputation)Veteran Member (734 reputation)Veteran Member (734 reputation)Veteran Member (734 reputation)Veteran Member (734 reputation)Veteran Member (734 reputation)Veteran Member (734 reputation)
Posts: 85, Visits: 583
It's been crashing iclone ever since I updated to 1.22. I've tried uninstalling and reinstalling both iclone itself and the plugin and it still crashes.
lianchiu
lianchiu
Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)
Posts: 214, Visits: 1.5K
Hi,
In some environments (like Alienware) with the dual-monitor may have this issue. CryingCrying
Before this issue fixed, here is the workaround:
1. Try to disable your extended monitor(ref: https://itstillworks.com/switch-dual-monitor-single-1209.html)
2. Open IC/CC and close it to makes IC/CC always open in the main monitor
3. Enable your extended monitor back.
4. Done BigGrin
* Not use the dock/undock function on the LiveLink
2 Workaround:
Disable Extended Monitor will fix temporary
Disable the on-board Graphic card
(for Notebook with dual graphics cards. Ext Alienware)
If not work, please submit a support ticket, we may need more information from you.
