Hi,
In some environments (like Alienware) with the dual-monitor may have this issue. CryingCrying
Before this issue fixed, here is the workaround:
2. Open IC/CC and close it to makes IC/CC always open in the main monitor
3. Enable your extended monitor back.
4. Done BigGrin
* Not use the dock/undock function on the LiveLink
2 Workaround:
Disable Extended Monitor will fix temporary
Disable the on-board Graphic card
(for Notebook with dual graphics cards. Ext Alienware)
If not work, please submit a support ticket, we may need more information from you.
