IC 7.9 New Feature: Alembic Importer
Posted By Eric C (RL) 4 Years Ago
Eric C (RL)
Eric C (RL)
Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)Distinguished Member (11.8K reputation)
Posts: 552, Visits: 6.0K
Alembic Import
Here's the answer for why we should importing alembic files to the iClone!
Introduction
Two new Alembic import options for iC7.9: Import Alembic Prop with Vertex Animation and Apply Alembic Vertex Animation.
Selecting some samples from our power users to demonstrate how you can use Alembic props in iClone.
  • IC7.9 - Alembic - (Test - 02) by Bassline 303
  • First Test Blender Ocean Alembic Import Iclone by rosuckmedia
(Note):
1 .Export abc form Maya and drag the abc file into the view-port to create a prop in iC7.9.
2.
If the abc file does not contain UV information then the created prop will, likewise, have no UV data.
https://forum.reallusion.com/uploads/images/d51884e6-e993-4b10-8d86-71a3.gif
Load Alembic Vertex Animation form file, or load abc Animation one at a time.
Import Vertex Animation by file:
https://forum.reallusion.com/uploads/images/0a1bb379-cdb6-4a58-b89e-1cd4.gif
Import Vertex Animation by folder:
https://forum.reallusion.com/uploads/images/37fe1e4b-9780-4bd4-aaed-6e56.gif
Users can select check this box and save all the abc meshes into one file, or separated files.
https://forum.reallusion.com/uploads/images/9606ada1-ebb6-4e40-83c9-0eda.jpg
Selecting save each meshes as separate file.
https://forum.reallusion.com/uploads/images/81be8fc1-1dd7-4faa-ab15-5fbe.gif
Not selecting save each meshes as separate file.
https://forum.reallusion.com/uploads/images/6a20265d-cbc0-4799-8b62-4861.gif
Note: Unreal Engine only supports one file one mesh Alembic files!
Alembic: Limitation
The internal structure of the abc files can not be edited, therefore any inconsistency between the Alembic Vertex Animation and the target mesh will result in a failure to load and apply the vertex animation.
Store and remove vertex animation
Find out more by checking the webpage
Warped Reality VFX
Warped Reality VFX
Posts: 386, Visits: 8.4K
Hello, I have 3DXChange pro due I need the pipeline version to import alembic files, I also CC3 Pipeline I don't know if that imports alembic files and I could go that route?
Warped Reality VFX.
Angel Alonso
Angel Alonso
Posts: 341, Visits: 1.3K
Alembic yes!
Eric C (RL)
Eric C (RL)
ATOOM (3/24/2021)
Alembic yes!
(HI FIVE)
depredor2018
depredor2018
Posts: 69, Visits: 295
I like how they gave us a screenshot of a menu option without telling us how to get to that menu or where it is. I went through every single menu on the top bar and didn't see any mention of a vertex animation
depredor2018
depredor2018
I like how they gave us a screenshot of a menu option without telling us how to get to that menu or where it is. I went through every single menu on the top bar and didn't see any mention of a vertex animation.
Never mind I noticed they show how to get too it after they tell you to do it and show you an obscure photo with no indication as to how to get too it lol.
depredor2018
depredor2018
I tried this and after spending a lot of time trying different methods everytime I imported my Alembic into my scene it was out of sync with the character animation I mapped it for. The scale was also slightly off. Would be nice if y'all were able to make this simpler.
Garry_Seven_of_one
Garry_Seven_of_one
Posts: 457, Visits: 1.9K
depredor2018 (7/22/2021)
I have the same problem. It a frame or two off position in the beginning compared to the iclone animation. I exported the anim as fbx instead to MD and it comes back ok. Not as practicle though.
Garry, Clearstream, Seven_of_one
https://forum.reallusion.com/uploads/images/f8c0246a-f887-417d-9f3c-b22c.png
My Pinterests
mila_647012
mila_647012
Senior Member (274 reputation)Senior Member (274 reputation)Senior Member (274 reputation)Senior Member (274 reputation)Senior Member (274 reputation)Senior Member (274 reputation)Senior Member (274 reputation)Senior Member (274 reputation)Senior Member (274 reputation)
Posts: 16, Visits: 199
I have a problem with this workflow between MD11 and IC8: the outfit gets imported without the vertex animation
I might be missing some steps or settings
Can anyone post a tutorial with the updated settings?
Wilby
Wilby
Veteran Member (843 reputation)Veteran Member (843 reputation)Veteran Member (843 reputation)Veteran Member (843 reputation)Veteran Member (843 reputation)Veteran Member (843 reputation)Veteran Member (843 reputation)Veteran Member (843 reputation)Veteran Member (843 reputation)
Posts: 131, Visits: 479
Kevin L (3/24/2021)
Late reply. Importing Alembic (.abc) files in iClone 7 is supported even without 3DXchange. But NOT exporting. CC3 Pipeline does NOT support Alembic (.abc) format.
In addition, to successfully export Smart Hair animations to Blender or other third-party tools, I think you will need to export to Alembic (.abc) format.
