How can I get my Motion LIVE 2d Plugin to actually work?
Posted By mansion7 5 Years Ago
mansion7
mansion7
Senior Member (356 reputation)Senior Member (356 reputation)Senior Member (356 reputation)Senior Member (356 reputation)Senior Member (356 reputation)Senior Member (356 reputation)Senior Member (356 reputation)Senior Member (356 reputation)Senior Member (356 reputation)
Posts: 13, Visits: 176
Hello!
I want to use the Motion Live 2d to animate character faces.  But, it seems to work very very very poorly.  I am willing to accept this might be MY issue, but I just don't now what I'm doing wrong.
I have tried several different cameras.  I have a very nice computer (I can run the wonderful Iclone just fine, for example), an HD camera, sufficient lighting, and a nice microphone.  I've never run across a program my computer can't handle, so I don't believe it's the computer.
On the face tracker, all the green dots appear just fine.  No problem there.
The problems are these:
1)   It is incredibly laggy.  There is absolutely no way I could do live streaming with my cartoon character, as one of the Cartoon Animator tutorials on the official channel showed.
2)  The lip sync is so bad as to be non-existent.  The green dots in the tracker are perfectly matching my lips, so I just don't understand the problem.  The character head moves around, the eyes close etc, but the lips just don't match.   This happens if I select the option for realtime lip sync OR post processing.
3)  The audio recording messes up.  I've tried it with and without audio, in hopes that will help the lip sync somehow.  When I have it turned on and do playback, the audio in Cartoon Animator sounds like The Man from Another Place, from Twin Peaks.  Backwards sounding gibberish.    Again I have a wonderful microphone and no other programs I have encounter these issues.
I would really REALLY love to make an animated avatar for myself, and also do facial mocap, but I just do not understand what am I doing wrong.  Are there known errors in this?  Are there some secret settings, or some "aha moment" tricks where it just works?  I would be SOOO grateful for any help with this matter.   I love Cartoon Animator and just want to take my animations to the next level.
Posts: 23.1K, Visits: 36.6K
Hi...
Sorry to hear you are having these problems.
There is clearly some kind of system specific issue going on because I don't have the problems you are having and recording facial motion capture is very smooth.
A few things to check first:
1. Make sure your system is fully updated by running Windows Update (Start > Settings > Update & Security) and also ensure your graphics drivers are up to date (very important).
2. If you have a computer that is always on, please do a full shutdown, then restart and run Cartoon Animator without any other applications running.
3. Before doing any facial motion capture, do ensure you have "Set Zero Pose" correctly.
4. Try recording facial animation first with "Record Audio" unchecked and then with "Record Audio" checked. Is the performance worse with Record Audio checked? (may indicate an audio driver conflict issue).
If after checking the above the issue is still the same, please contact Technical Support using the link below and supply your system information (dxdiag.txt). Also if possible, try to include a video screen capture showing exactly what happens when you try to use Motion LIVE 2D. Once Support have this information they should be able to help you resolve the problem.
