[What's New] Releasing Unreal Live Link v1.22 for iClone (UE4.26 compatible!)
Posted By Eric C (RL) 5 Years Ago
[What's New] Releasing Unreal Live Link v1.22 for iClone (UE4.26...
Ghetzi
Ghetzi
Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)Senior Member (279 reputation)
Posts: 14, Visits: 94
antoniojosecastilla (6/11/2021)
Ghetzi (12/31/2020)
Ghetzi (12/29/2020)
Glad to see this was updated to 4.26.  Unfortunately, I'm having problems compiling our project after enabling the auto-setup plugin.  Uninstalling the update resolves the problem, and a fresh install still results in a compile error.  I've got a support ticket in, but thought I'd comment here in case anyone else searching has an issue.  The update is only a day old, these things happen.  Will wait and update here once I find a solution!
UPDATE:  Support's position on the matter is that the auto-setup plugin can only be installed in a new 4.26 project and will not work on an existing, already-in-progress 4.26 project.  Which seems off to me, but that's what they said so there must be a reason.  As a workaround, we're going to start a blank 4.26 project to work the characters, and then use the UE4 migrate tool to bring them into over to our main project which is already in mid-development.  Unless anyone else has any bright ideas?
Did you find any other solution?
Unfortunately, no. The only work-around for an 4.26 projected updated from a previous version was to use a side project as I mentioned and then migrate. For a while, I was able to disable the plugin after each use, but even that stopped working after a while.  Fortunately, that project is done and we were able to start a new project in 4.26 and haven't had an issues since, but I recognize that doesn't help you very much, sorry.
antoniojosecastilla
antoniojosecastilla
Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)Junior Member (246 reputation)
Posts: 22, Visits: 114
Ghetzi (12/31/2020)
Ghetzi (12/29/2020)
antoniojosecastilla
antoniojosecastilla
Hi, i have a problem with unreal 4.26.2, when i try to start the project, after pasting the unreal live link 4.26 folder, i get the error:
"The following modules are missing or built with a differente engine version:
RLLiveLink
RLLiveLinkEditor
Would you like to rebuild them now?"
The rebuild doesn't work, and i don't know what to do. Auto setup is working fine, and both of them were working fine in 4.25.
Anybody can help me, please?
ninjarama
ninjarama
New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)New Member (54 reputation)
Posts: 12, Visits: 143
Thanks for the replies!  Looks like I'll have to try Bootcamp... I appreciate your time @mkoo and @lianchiu!
Melvin (RL)
Melvin (RL)
Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)Senior Member (374 reputation)
Group: Moderators
Posts: 83, Visits: 1.7K
ninjarama (1/8/2021)
Are the Unreal Live Link and Auto-Setup plugins compatible with UE4.26 on the Mac?  Any tips on how to get this working on Mac?  I would like to be able run iClone on my PC and Live Link to my Mac.
Happy New Year!
Hi
Unfortunately, the version of Autosetup and Livelink doesn't support Mac system now.
lianchiu
lianchiu
Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)Veteran Member (645 reputation)
Posts: 214, Visits: 1.5K
Happy New Year!
Here are system-requirements
happy new year
ninjarama
ninjarama
Happy New Year!
Ghetzi
Ghetzi
lianchiu (1/6/2021)
i started a new project 4.25 (NO Auto setup and Live Link) there are some prop and Character in project 4.25 then I convert the project from 4.25 to 4.26.
After that I install the Auto setup for 4.26, and using Auto Setup to import FBX from CC and IC. no issue.
so could you please record your workflow and show the error message.
I got this message is because i was using Auto setup for 4.25 but i opened it in 4.26
but in your case that you said you didn't use auto setup for 4.25 so i guess is different issue.
so please let us know what the workflow if you are not comfortable put in here you can PM me or submit to Feedback Tracker and leave the private comment
Thanks for being persistent in trying to help!  I didn't want to spam the forum, so I opened a new issue on the feedback tracker.  Our workaround of disabling the auto-setup plugin after using it is working fine, as the compile issue only happens when the plugin is enabled in the engine.  Also, the Live Link plugin is working fine and presents no compile issues, enabled or not.  So the issue is confined to auto-setup.  Thanks again!
lianchiu
lianchiu
Ghetzi
Ghetzi
lianchiu (1/4/2021)
Ghetzi (12/29/2020)
One question : Did you also copy CC_Shader from 4.25 into 4.26?
Thanks for the reply and trying to help!  At the time of the project conversion from 4.25 to 4.26, we did not yet have CC3 and iClone7, so the autosetup was never installed to the project prior to converting.  We installed the updated plugin for 4.26 once I began using CC3 & IC7.  The iClone7 Live Link is working great, but not auto-setup.  For now, disabling the autosetup plugin in UE4 seems to be working fine.  We enable it to import from CC3 and run the setup (which works fine) and then disable it when we're done.  No compiling or packaging issues that way so far.  FWIW - support said the autosetup plugin will not work on projects converted from 4.25 to 4.26, and that it only works for projects started in 4.26.  Not sure why that is, but that's what they said.
