What performance do YOU get in the courtyard scene?
Posted By FallenNInja 5 Years Ago
FallenNInja
FallenNInja
Posts: 56, Visits: 1.4K
I'm running a 2080 TI and 10850k and I'm getting around 35-40fps in the courtyard scene with a 3440x1440 monitor. Is this normal or should I be concerned?
Adding a few characters to a scene severely tanks performance and I'm concerned that this will hinder my ability to create content.
Please share your thoughts.
Posts: 9.2K, Visits: 22.1K
Well, I can tell you MY thoughts but I don't know how helpful they will be because my settings are so different than yours.
But running at HD mode on my dual monitors, with my Titan, that scene is trivial (for one thing, it doesn't even take 1GB of memory).  I get 60fps during playback but more than that, moving around the scene is as fast as if there is nothing in the scene at all.
I added three CC3+ characters to bring the total scene size up to around 4.5GB and it STILL is lightning fast (and this is with everything checkmarked and running in the high display mode).  I'm guessing I can cripple this -- another six characters will most likely destroy me but the rule of thumb is as long as you are under your GPU memory (in my case, 12GB) things shouldn't slow down much unless there are other factors (transparency and mirroring being an issue we are well aware of).  So I could work with six characters in this scene very comfortably but 9 or 10 would be challenging if not impossible (unless I resorted to tricks like removing res for background characters or such).
My gut tells me there must be something wrong with your system but, again, your specs are so different I don't know.  Can you run it in HD to compare?  If it runs well in that mode then you know where the issue is (I can't run my system any higher to check the opposite way).
toystorylab
toystorylab
Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)Distinguished Member (17.3K reputation)
Last Active: 4 days ago
Posts: 4.6K, Visits: 29.9K
I don't have time to add stuff to the scene but I get avarage 43 fps (High Mode) with these specs:
75% of original size (was 674x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/44c43880-9eda-40b2-a47b-c391.png
Toystorylab on Vimeo : 75% of original size (was 674x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/ce44ea78-6984-47d8-9bf4-b783.png    Crassitudes (my "Alter Ego") on Youtube: 75% of original size (was 674x19) - Click to enlargehttps://forum.reallusion.com/uploads/images/fcc4df30-b3a8-40a5-a427-0735.png
jlittle
jlittle
Posts: 1.9K, Visits: 17.3K
I get 60fps with 0.8G of 11Gb video memory in High Mode.
When I add four (4) CC Characters I drop to around 50fps.
System:
  • NVIDIA GeForce RTX 2080 Ti (11GB)
  • CPU i9-9900K @ 3.6GHz (8 Core)
  • ROG STRIX Z390-H GAMING (Mother Board)
  • 64GB Ram
  • Win 10 Pro
Jeff
FallenNInja
FallenNInja
Performance tests in HD
Default scene 60 fps.
6 characters
825336 project triangles
277359 triangles per character
4.2/11gb of ram
1 fps :(
3 characters
547977 project triangles
4.2/11gb of ram (seems weird - I removed 3 characters from the previous test)
13fps
Does this performance seem right? - jlittle and I have similar specs, however he seems to be getting much better performance.
I'm going to re-install and report back.
If that doesn't help I'm going to switch from the latest Nvidia gaming driver to their latest studio driver.
jlittle
jlittle
My video driver: GeForce Game Ready Driver V457.51
Jeff
FallenNInja
FallenNInja
Reinstalled application, rolled back driver to latest studio driver.
No performance gains. I'm going to try jlittles driver and then report back. Will be contacting customer support aswell. Thank you all.
Just in case, since you ARE getting 60fps with no characters and it's only the characters dragging you down, why don't you post your scene here?  (Assuming you use the default avatars that come with iClone).  Let us try to make sure we are comparing apples to apples.
FallenNInja
FallenNInja
Kelleytoons, you hit the nail on the head. It seems that my performance woes came primarily from my custom characters not being optimized enough for real time rendering.
