CC3 - Rcover data after crash
Posted By TTneedsHelp 5 Years Ago
TTneedsHelp
TTneedsHelp
New Member (78 reputation)New Member (78 reputation)New Member (78 reputation)New Member (78 reputation)New Member (78 reputation)New Member (78 reputation)New Member (78 reputation)New Member (78 reputation)New Member (78 reputation)
Posts: 2, Visits: 11
Kind of an emergency here:
I'm the kind of person who ALWAYS saves every minute, BUT I had to learn the hard way that CC3's 'save'-function DOES NOT WORK CONSISTENTLY. Purchased the software yesterday, and had my first crash (something about inaccessible data, but that's not the issue right now) after around ten hours of usage today. Unfortunately, I have lost all progress from the last six hours, which is a HUGE bummer.
My question is: How do I restore the data from the temp folder? I have made a copy of its contents, but can't seem to find an option inside CC and neither are there any helpful threads online. PLEASE HELP, I really do not want to end up refunding my purchase - Although I have been enjoying everything so far, I won't continue using unreliable software where I can't even restore after inevitable crashes.
EDIT: I'm super clumsy and accidentally clicked away the "restore project from temp folder" dialog when I restarted after the crash. Apparently that dialog only appears once :(
kmitchell.12catblackstudio...
Posts: 257, Visits: 1.1K
Also when starting a new character make sure you hit Save As to start a new save file. I've had this issue with the file nor saving because the new file was not a real place on my drive yet. But once you save as and then use save it will indeed save to the location.
r78zj99
r78zj99
Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)Veteran Member (528 reputation)
Posts: 122, Visits: 203
what kmitchell.12catblackstudio... has said is true most of the time
I have test my own version by forcing a crash (today)
you should have this pop up when restarting again, see picture.
https://forum.reallusion.com/uploads/images/8442ccde-8834-4f0d-8820-4c6c.jpg
the most important step is to 'ok' it
other wise all is lost!
it give you the chance  to rename the file
if all is to your liking
now the next important step
come out of the programme
clean up your system on your machine
reboot it again
recall your work again
it should be 'ok' this time round
say after every 10 mins do a save
check this by doing an tab to tab
on your file explorer
happy designing
from Alan
TTneedsHelp
TTneedsHelp
@r78zj99
Thanks for the advice, I wish I had known about this before I reopened CC after the crash.
Since I hit "Cancel" the first time after the crash, all temporary data has been overridden/lost (as you said) before I made the backup unfortunately, meaning that I am unable to restore my progress. I have also tested crashing it by force yesterday and reloading my backups from the AppData/Local/Temp folder by replacing the files in /Restore and /CharacterCreator3Temp, which is also how I found out that the copied temporary data was from after the crash and my progress has been wiped.
As I am typing this, I have already accepted what's happened and am remaking yesterday's project (while always double checking the save file lol).
@kmitchell.12catblackstudios
Thank you for the heads up, will make sure to do that in the future!
