auto setup tool
Posted By pfitzuk 5 Years Ago
pfitzuk
pfitzuk
Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)Junior Member (151 reputation)
Posts: 7, Visits: 102
i am really getting frustrated with the auto update tool i have spent a small fortune on reallusion products and this tool is never working properly with the unreal engine
25.3 has been out for a while now and all i get is this is not compatable with this version of update tool
and whenever i import anything and start using the pro version of skin gen it crashes all the damn time
and the tutorials need to be up to date better using the newest version of unreal
ahhhh
unit23
unit23
Posts: 115, Visits: 380
pfitzuk (10/22/2020)
The latest is AutoSetup 1.1, and you need to install it, then browse to the installation folder for 4.25, and manually copy the content into your project plugin folder. This also has to be done when rebuilding the project (in case you converted to a C++) version.
Skin gen is slow here, possibly because it uses 4K textures per default, which is overkill imho.
pfitzuk
pfitzuk
yes i did that and i have 1.1 but says the same thing
AlbertDup
AlbertDup
New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)New Member (18 reputation)
Posts: 2, Visits: 38
I am also struggling, updated to all the latest versions and I am only able to select the standard shader. The LW and HQ shaders are greayed out and I am unable to sellect them. Plugin loads without errors in 4.25.4
EDIT: Solved, I forgot to copy the shaders to a new project
Procrastinator
Procrastinator
Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)Veteran Member (897 reputation)
Posts: 76, Visits: 980
For those using 4.26, just migrate the char over from 4.25 version.
