auto setup tool
https://forum.reallusion.com/Topic461070.aspx
Print Topic | Close Window
By pfitzuk - 6 Years Ago
i am really getting frustrated with the auto update tool i have spent a small fortune on reallusion products and this tool is never working properly with the unreal engine
25.3 has been out for a while now and all i get is this is not compatable with this version of update tool
and whenever i import anything and start using the pro version of skin gen it crashes all the damn time
and the tutorials need to be up to date better using the newest version of unreal
ahhhh
By unit23 - 6 Years Ago
pfitzuk (10/22/2020)
The latest is AutoSetup 1.1, and you need to install it, then browse to the installation folder for 4.25, and manually copy the content into your project plugin folder. This also has to be done when rebuilding the project (in case you converted to a C++) version.
Skin gen is slow here, possibly because it uses 4K textures per default, which is overkill imho.
yes i did that and i have 1.1 but says the same thing
By AlbertDup - 6 Years Ago
I am also struggling, updated to all the latest versions and I am only able to select the standard shader. The LW and HQ shaders are greayed out and I am unable to sellect them. Plugin loads without errors in 4.25.4
EDIT: Solved, I forgot to copy the shaders to a new project
By Procrastinator - 6 Years Ago
For those using 4.26, just migrate the char over from 4.25 version.
