Hair kinks when used on different models
Posted By jerome.dipietro 6 Years Ago
jerome.dipietro
jerome.dipietro
Posts: 91, Visits: 1.1K
I've imported my own hair models as per the tutorials. (Import as accessory, fitted onto Female neutral base then used transfer skin weights to create the hair asset. Add to Custom Content tab)
https://forum.reallusion.com/uploads/images/6d520002-55c9-4c8c-8e0d-a79c.png
The problem I have is that when reused on another character (a headshot model I've created) kinks appear in the hair strands:
https://forum.reallusion.com/uploads/images/9debc2d9-0d54-4ce5-8b94-4aa3.png
What can I do to either remove these on the new model or, ideally, fix the original 'master' so that it can be applied to any model?
I've been looking at the Fixing Visual Defects videos, i.e. manually painting Skin Weights, but I'm unsure how to apply the techniques shown for clothes on my hair strands.
For example, when I select some of the problematic vertices I just see a simple value of 1 on just one bone (CC_base_Head) and the same for the surrounding vertices:
https://forum.reallusion.com/uploads/images/547dca28-e98c-4d2d-bab4-b221.png
I don't understand why the kink is being created.
Any help or advice with applying skin weights to hair would be very much appreciated.
Unity Virtual Reality Developer
Posts: 9.2K, Visits: 22.1K
Change the hair to an accessory (don't weight it as hair).
jerome.dipietro
jerome.dipietro
Ah! ok :) yeah that works but it's confusing to a newcomer... why then have the hair category?
Thanks for the reply
Posts: 15.8K, Visits: 31.4K
jerome.dipietro (10/8/2020)
I believe accessories remain static so it will behave differently when the head is moved. It least that's how it used to be...:unsure:
As long as you have a weight map on it it will look exactly the same.  The only difference is something weighted as hair will then have the shoulders conform it (but a physics weight map will handle that as well).
jerome.dipietro
jerome.dipietro
Thanks Kelleytoons, it does make sense that the shoulder bones would have an effect. What's odd to me is that the vertex I have highlighted in my screenshot, according to the Skin Weights panel, is only conforming to the head bone, as are the vertices adjacent to it (and all of them with the same weight of 1). That's why I don't see where the kink comes from.
Very much appreciate your suggestions for workarounds. Sadly the physics weight map isn't available to me, as far as I understand things, as I'm exporting to Unity.
