luke (RL)
luke (RL)
Group: Power Developer
Visits: 5.6K
Hi, Vidi I found the root cause is 3d-coat don't support bone so you see the native A-pose in it. If your favor software is zbrush and 3d-coat, I will suggest you to use obj (with Bind pose) as a major file format. thanks,
Luke
vidi
Posts: 10.8K,
Visits: 40.2K
The other Problem still keep, I can not use the obj UDIM Layout in 3D coat , I need the old Std UV Set. Finally I have found an alternative workflow, also for the baking the in 3D Coat. For me is baking in 3D coat better , because there is a visual Baking cage even if a bit more complicated as before, but I'm finally happy that I get further. These Pose Bug and new obj UDIM Layout got into a mess my previous working workflow.
The solution for baking in 3D coat now I Import a CC FBX as pixel painting , because that keep the Std UV sets . In the Retopo Room I use option "Take mesh from Paintroom" and export this Retopo Mesh as OBJ. Then, I start new with the High Poly Mesh via vertex paint import and imported in the Retopo Room the the previously exported Retopo Mesh. Now can I bake.
Now can I use all benefits of both together, 3D Coat and Substance Painter. :cool:
Now that's a temporary fix, however the "V Pose Issue" need to fix and obj export should get a additional Option to export with old Std UV set .
vidi
Posts: 10.8K,
Visits: 40.2K
Ok I get it only working with set to A Pose. after all a Bright spot only T Pose make trouble . When T Pose obsolete why have we this option? Why have we a Extra Button to load neutral Base that set the Avatar in the T Pose ? That makes all not sense. To get a neutral base Avatar that works (A Pose) need to reset the morphslidersand not press Button "load neutral Base" !!! T Pose is absolute nonsens now.
vidi
Posts: 10.8K,
Visits: 40.2K
When I use an old CC Mesh it generate nona FBX key, therefore also that is a dead end I can try what I want, I can no longer work with this CC version.:angry:
vidi
Posts: 10.8K,
Visits: 40.2K
Here the result if I set T Pose in the FBX Exportmenue :doze:
vidi
Posts: 10.8K,
Visits: 40.2K
That has to be related to this A and T pose thing If I send a character in the T pose to Zbrush and set as an A pose in the update Menue , I get the same V pose result. But I use the Create Morph menu and exported a T pose and import the mesh as a Tpose. I cannot choose which pose should be set in the Create Morph menu, so I have no influence on it. This is a bug TPose to A Pose = VPose
vidi
Posts: 10.8K,
Visits: 40.2K
it shouldn't matter which software you use, if the mesh has a static T pose it should stay that way. Anyway the new UV layout and no longer suitable export for baking is even the bigger problem now
that really annoys me, because now I have time and can't make any headway
Posts: 5.3K,
Visits: 16.8K
Hey Vidi, I know, there are lots of problems with current Bind pose and exports/imports. But frankly, creating Morph Sliders from OBJ is not one of them (at least not for me with Blender workflow). Wonder what you do different to get that weird result...
vidi
Posts: 10.8K,
Visits: 40.2K
Update When I want not use CC+ now other Generation are greyed out for Zbrush :crazy: My whole workflow is actually broken in every task .
BTW here to see waht happend when I use a Tpose as Morph.
vidi
Posts: 10.8K,
Visits: 40.2K
Thank you for the feedback Vidi. If you have reported the issue in the Feedback Tracker the CC team will investigate and you should receive a status update soon.
Do that Think really work ?
