By vidi - 5 Years Ago
Why get it now , if I export a TPose and import a Morph with TPose at the end V Pose ? Why are the arms affected when I have nothing change in this area?
That has worked flawless before CC + an A Pose was implies Pleace can you fix this ? :angry:
O man it is really a showstopper nothing works like before, all work for hours is now for the trash. My morph do nothing if I use a CC+ Default Character and also my old morphs looks ugly deformed now. I have only change the head geometry but if i drag my morh slider the head looks not different but the Arms get a VPose Is only GOZ working if yes WHY? Can I not more more create Morphs outside of thos pipeline?
By 4u2ges - 5 Years Ago
It is a global issue and there is much more to it. I have already opened 3 tickets in FT for similar problems. Please add your issue as well.
Ok I hope we get a fix otherwise is usless to create morphs for me https://www.reallusion.com/FeedBackTracker/Issue/CC-make-a-V-Pose I hate it when the working workflow breaks with new updates
no matter what I try curent pose binding pose .... only waste of time :angry:
By Peter (RL) - 5 Years Ago
Thank you for the feedback Vidi. If you have reported the issue in the Feedback Tracker the CC team will investigate and you should receive a status update soon.
No feedback so far :crying: A Update > It's worse than that :angry: Actually CC is absolutely useless now for development nothing fits correctly more. FBX current pose is not current OBJ has a massive offset therefore nothing fits more for bake maps
That needs to be fixed! t's so annoying when an update just breaks everything instead of improving it
Thank you for the feedback Vidi. If you have reported the issue in the Feedback Tracker the CC team will investigate and you should receive a status update soon. Do that Think really work ?
Update When I want not use CC+ now other Generation are greyed out for Zbrush :crazy: My whole workflow is actually broken in every task .
BTW here to see waht happend when I use a Tpose as Morph.
Hey Vidi, I know, there are lots of problems with current Bind pose and exports/imports. But frankly, creating Morph Sliders from OBJ is not one of them (at least not for me with Blender workflow). Wonder what you do different to get that weird result...
it shouldn't matter which software you use, if the mesh has a static T pose it should stay that way. Anyway the new UV layout and no longer suitable export for baking is even the bigger problem now
that really annoys me, because now I have time and can't make any headway
That has to be related to this A and T pose thing If I send a character in the T pose to Zbrush and set as an A pose in the update Menue , I get the same V pose result. But I use the Create Morph menu and exported a T pose and import the mesh as a Tpose. I cannot choose which pose should be set in the Create Morph menu, so I have no influence on it. This is a bug TPose to A Pose = VPose
Here the result if I set T Pose in the FBX Exportmenue :doze:
When I use an old CC Mesh it generate nona FBX key, therefore also that is a dead end I can try what I want, I can no longer work with this CC version.:angry:
Ok I get it only working with set to A Pose. after all a Bright spot only T Pose make trouble . When T Pose obsolete why have we this option? Why have we a Extra Button to load neutral Base that set the Avatar in the T Pose ? That makes all not sense. To get a neutral base Avatar that works (A Pose) need to reset the morphslidersand not press Button "load neutral Base" !!! T Pose is absolute nonsens now.
The other Problem still keep, I can not use the obj UDIM Layout in 3D coat , I need the old Std UV Set.
The other Problem still keep, I can not use the obj UDIM Layout in 3D coat , I need the old Std UV Set. Finally I have found an alternative workflow, also for the baking the in 3D Coat. For me is baking in 3D coat better , because there is a visual Baking cage even if a bit more complicated as before, but I'm finally happy that I get further. These Pose Bug and new obj UDIM Layout got into a mess my previous working workflow.
The solution for baking in 3D coat now I Import a CC FBX as pixel painting , because that keep the Std UV sets . In the Retopo Room I use option "Take mesh from Paintroom" and export this Retopo Mesh as OBJ. Then, I start new with the High Poly Mesh via vertex paint import and imported in the Retopo Room the the previously exported Retopo Mesh. Now can I bake.
Now can I use all benefits of both together, 3D Coat and Substance Painter. :cool:
Now that's a temporary fix, however the "V Pose Issue" need to fix and obj export should get a additional Option to export with old Std UV set .
By luke (RL) - 5 Years Ago
Hi, Vidi I found the root cause is 3d-coat don't support bone so you see the native A-pose in it. If your favor software is zbrush and 3d-coat, I will suggest you to use obj (with Bind pose) as a major file format. thanks,
Luke
