Eric C (RL)
Eric C (RL)
Last Active: 4 days ago
Visits: 6.0K
Dear iCloners,
The iClone 7.81 update has now been released! This update fixed a total of nine issues, and added one enhancement. You may find the Update tab in Reallusion Hub to download the patch. See the full release note below: Patch 7.81 info
Enhanced: FBX asset renaming is now structurally compatible with Unreal. Fixed: Unable to pick bones in the viewport under Edit Motion Layer mode. (#FT7136) Fixed: Picking a Substance material causes some projects to crash. Fixed: iClone and Character Creator crashes from repetitive docking and undocking of the Smart Gallery, Curve Editor, and Live Link panels. Fixed: Some projects lag on playback. Fixed: UV adjustments not taking effect for some props. Fixed: Some characters exported in FBX fail to load into Blender. Fixed: $time variable not working for Substance materials in iClone. (#FT7063) Fixed: Displacement channels can't utilize Substance materials and Bake Substance Texture is disabled. (#FT7087) Fixed: Sbsar blurriness caused by failure to set the output size. (#FT7134)
Thank you!
Reallusion Team
Galfridus
Galfridus
Visits: 2.2K
Thank you for the patch RL Team. Very pleased to have the $time variable for Substance materials working once again in Iclone. Geoff. :)
Kreative High
Kreative High
Visits: 26
We're having issues loading iClone 7 and Character Creator 3 since the update to 7.81. Has there been any other users with this issue?
Posts: 23.1K,
Visits: 36.6K
Kreative High (9/11/2020) We're having issues loading iClone 7 and Character Creator 3 since the update to 7.81. Has there been any other users with this issue?Have you tried updating your graphics drivers? After a new update iClone may not run if you have outdated drivers so it's worth a check.
Kreative High
Kreative High
Visits: 26
Problem solved. My system updated and my programs were not being opened with my new graphics card. Totally my system and not a Reallusion problem. Thanks for your help though.
