Dear iCloners,
The iClone 7.81 update has now been released! This update fixed a total of nine issues, and added one enhancement.
You may find the Update tab in Reallusion Hub to download the patch. See the full release note below:
Patch 7.81 info
Enhanced: FBX asset renaming is now structurally compatible with Unreal.
Fixed: Unable to pick bones in the viewport under Edit Motion Layer mode. (#FT7136)
Fixed: Picking a Substance material causes some projects to crash.
Fixed: iClone and Character Creator crashes from repetitive docking and undocking of the Smart Gallery, Curve Editor, and Live Link panels.
Fixed: Some projects lag on playback.
Fixed: UV adjustments not taking effect for some props.
Fixed: Some characters exported in FBX fail to load into Blender.
Fixed: $time variable not working for Substance materials in iClone. (#FT7063)
Fixed: Displacement channels can't utilize Substance materials and Bake Substance Texture is disabled. (#FT7087)
Fixed: Sbsar blurriness caused by failure to set the output size. (#FT7134)
Thank you!
Reallusion Team
