iClone .fbx file into Unity 3D Renaming and Event Problem
Posted By Velo2 6 Years Ago
Velo2
Velo2
New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)New Member (96 reputation)
Last Active: 6 Years Ago
Posts: 4, Visits: 27
When I bring an FBX file exported from iClone 7 into Unity 3D (without using the autosetup plugin), there are no model or animation options in the inspector within Unity.  To remedy this, I see Reallusion has supplied an AutoSetup script which somehow fixes this -- and you can once again see the model and import animation settings for the character within Unity 3D.
However, even when using the provided AutoSetup script, I still am not able to rename any animations within Unity created by iClone.  Is there a way to do this?  In addition, within Unity's mecanim animation system I am not able to create any mecanim animation "Events" by which to call function's via these animations.   **Note:  I have ensured that the AutoSetup option is "unchecked" in the "Character Creator & iClone Autosetup" options.
So to sum up, any animations I import into Unity created with iClone7, I cannot currently rename, and I cannot call any functions from these animations using Unity's mecanim animation system.  Is there any way to fix this, or am I missing something I should be doing?  Thank you for any help.
Threaded View
