Last Active: 6 Years Ago
Visits: 27
When I bring an FBX file exported from iClone 7 into Unity 3D (without using the autosetup plugin), there are no model or animation options in the inspector within Unity. To remedy this, I see Reallusion has supplied an AutoSetup script which somehow fixes this -- and you can once again see the model and import animation settings for the character within Unity 3D.
However, even when using the provided AutoSetup script, I still am not able to rename any animations within Unity created by iClone. Is there a way to do this? In addition, within Unity's mecanim animation system I am not able to create any mecanim animation "Events" by which to call function's via these animations. **Note: I have ensured that the AutoSetup option is "unchecked" in the "Character Creator & iClone Autosetup" options.
So to sum up, any animations I import into Unity created with iClone7, I cannot currently rename, and I cannot call any functions from these animations using Unity's mecanim animation system. Is there any way to fix this, or am I missing something I should be doing? Thank you for any help.
