Posts: 1.0K,
Visits: 9.9K
Before attaching the head to the character, select the Head bone first.
 YouTube Tutorials Here
catmixian
catmixian
Visits: 3
Hi, I've been having the same kind of problem. I've been trying to put a photo head on a character. I've followed the video tutorials, put a frame on the head, masked out the background etc and saved it in the custom template.When I try to put it on a character it appears and I resize to fit but it will not stay on the body when moving around. I'm a newbie and probably doing something wrong that is obvious. Help!!!!.
aecaswell
aecaswell
Visits: 24
Ok, I found the solution. For some reason it was seeing my characters head as a full character. The solution to this for anyone who may be having the same problem, is to go to "Windows" at the top of your screen, and open the "Content Manager". On the side of the pop up are different tabs, click the one that says "Actor". Now up at the top there are two options, "Template" and "Custom", click "Custom". Click on the option that says "Head", and there shouldn't be anything there. If there are already heads there that you did not design, you aren't in the "Custom" tab. Once you find the empty head tab, click on your character's head then hit the plus sign at the bottom of the "Content Manager", and it should insert your head as a custom head. Once you have it as a head and not as a character, it will allow you to give it a body and all will be well.  Hope this helps!
aecaswell
aecaswell
Visits: 24
So I have a head for my character and I have a body, but no matter what I do, it will let me see one or the other but won't put them together. I keep getting an error message that says the "bone structures between target and source character are different", even when I remove or alter all of the body's bones. How do I give my character a head? Thanks
