Spring system not behaving as expected.
Posted By Peter_914185 5 Years Ago
Peter_914185
Peter_914185
Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)Senior Member (402 reputation)
Posts: 18, Visits: 83
Hi,
First off, sorry if this is a double post, I did post earlier but it doesn't seem to exist anymore.
I've got an issue uinsg the spring system. I've tried using it in 3Dxchange but when I apply springs to the joints I have set up for ears the spring system seems to bounce around way too much, even when everything is set to the lowest settings and just rotate. I don't think it's even obeying the rotation command as they joints seem to be translating too.
So I then downloaded the spring plugin for I clone, hoping that would do the trick. But I can't find how you apply it to joints that are part of the extended bone range.  It just seems to allow you to select templated bones.  Any ideas how I could apply this spring system to ears of my character?
Thanks in advance,
Threaded View
Threaded View
Forum Post Spring system not behaving as expected. By Peter_914185 ( 5 Years Ago )
