By Peter_914185 - 6 Years Ago
Hi,
First off, sorry if this is a double post, I did post earlier but it doesn't seem to exist anymore.
I've got an issue uinsg the spring system. I've tried using it in 3Dxchange but when I apply springs to the joints I have set up for ears the spring system seems to bounce around way too much, even when everything is set to the lowest settings and just rotate. I don't think it's even obeying the rotation command as they joints seem to be translating too.
So I then downloaded the spring plugin for I clone, hoping that would do the trick. But I can't find how you apply it to joints that are part of the extended bone range. It just seems to allow you to select templated bones. Any ideas how I could apply this spring system to ears of my character?
Thanks in advance,
