Springs, not working as expected
Posted By Peter_737068 5 Years Ago
Peter_737068
Peter_737068
Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)Veteran Member (533 reputation)
Posts: 45, Visits: 184
Hi,
I've been trying to get springs to work on one of my characters in 3Dxchange. The springs work but they move about severely even when the springs are set to a minimum amount. This is for a characters ears.  I've place the joints in the correct places and set the springs to just rotate but no matter what level I put the bounce, stiffness at the ears still rotate and even seem translate from their main position way too much.
I then discovered the Iclone spring plugin and thought that would be idea but I can't seem to find a way to select joints that aren't in the templated selection set. Does anyone know if it's possible to select things like ear joints using this method?
Thanks in advance,
Threaded View
Threaded View
Forum Post Springs, not working as expected By Peter_737068 ( 5 Years Ago )
