Springs, not working as expected
https://forum.reallusion.com/Topic450847.aspx
Print Topic | Close Window
By Peter_737068 - 6 Years Ago
Hi,
I've been trying to get springs to work on one of my characters in 3Dxchange. The springs work but they move about severely even when the springs are set to a minimum amount. This is for a characters ears.  I've place the joints in the correct places and set the springs to just rotate but no matter what level I put the bounce, stiffness at the ears still rotate and even seem translate from their main position way too much.
I then discovered the Iclone spring plugin and thought that would be idea but I can't seem to find a way to select joints that aren't in the templated selection set. Does anyone know if it's possible to select things like ear joints using this method?
Thanks in advance,
