mila_647012
mila_647012
Visits: 197
Dear all,
My PN plugin on iClone 7.3 is not working.
It was working on an old computer. I just upgraded my computer purchasing this one yesterday: OMEN by HP 17-cb0010nl Notebook Gaming PC, Core i7-9750H, 16GB di RAM, SATA 1TB & SSD 256GB, Nvidia GeForce RTX 2070, Display 17.3 FHD IPS
I’ve installed axis neuron software by copying the downloaded .exe file from the other computer where it was already installed. I haven’t uninstalled the hub and Axis software from the other computer yet
I installed the Axis neuron software, following the procedure. It all works correctly
When I open iClone, it sees the device, it gives me the right IP address, it connects, but the character is not moving I’ve tried different characters, none of them is moving
I can import the bvh version through 3DXchange as a workaround for now, but obviously it cannot be a solution
Any idea why it might not be working?
Additional info that I can think of in case it might be helpful:
I also retried on the other laptop that I was using before and now il experiencing the same problem
The way I installed live motion plugin and perception neuron was by downloading the Charcater Creator Hub from the link on my receipt and then installing everything though the hub. I was asked for the serial number of one or two products. It didn’t ask me for the serial number of perception neuron plugin
Live face is working without any problem whatsoever
I haven’t bought the leap motion controller yet so cannot try the leap motion plugin yet
Mila
Posts: 9.1K,
Visits: 21.7K
Mila, You have to do two things: first, in Axis Neuron go to the panel Settings and in General change the number of the port to 8009 (from 7009). Now in Motion Live make sure you use this port (instead of 7009, which it will fill in automatically). All should be well then.
