Failed to Connect to Perception Neuron
Posted By kent_310387 4 Years Ago
kent_310387
kent_310387
Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)Veteran Member (523 reputation)
Posts: 12, Visits: 114
I have Perception Neuron Studio.  Trying to connect to iClone->Motion Live Plugin->Perception Neuron.    I get Perception Neuron all set up in Axis.  Everything is working fine in Perception Neuron.  I set up BVH broadcast using Skeleton: Perception Neuron Studio, BVH Format YXZ with Displacement, Frame format as binary, and coordinate system as OPT, Protocol as TCP with my local IP address on port 7001.    When I try to connect from iClone, I am using my local IP address:7001, but when I try to connect it give me a Failed to Connect to Perception Neuron.    Any ideas?
-kent
Last Active: 12 hours ago
Posts: 9.2K, Visits: 21.8K
Try 8001 instead (on both ends).
animaliok
animaliok
Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)Junior Member (120 reputation)
Posts: 8, Visits: 355
Couldn't connect as-well and found the source of the issue: In Axis studio parameters, changing the addresses and port is only applied once you close the setting window (press ok) so you need to match the adress in Motion, live, then close the Axis settings, THEN only press the green dot in Iclone.
That's a big UX issue I will try to feedback Noitom as absolutely 100% of people would expect an adress change to take effect immediately if there is no "APPLY" button in the settings, as it's counter intuitive to have to close a window and re-open it just to tweak a settings. (as you need to look at the number you need the settings windows open, but if you don't close it the displayed address is not the actual active addres.....)
