jcforsy
jcforsy
Visits: 69
I have a project I have built using character and animation from IClone. The project runs in preview fine, but after packaging the project, when I try to open it, the application crashes and in the log, there is the message below
LogPluginManager: Error: Unable to load plugin 'RLPlugin'. Aborting. LogCore: Engine exit requested (reason: EngineExit() was called) LogExit: Preparing to exit.
I have moved the files for the CC3 Iclone plugin into the project folder, and within Unreal, the CC3 Iclone plugin shows as being enabled
jcforsy
jcforsy
Visits: 69
Found the problem. I need to have the RLPlugin disabled when I build the Unreal Engine project...
hakzolot
hakzolot
Visits: 31
what do you mean by you disabled the RLPlugin? when I disabled it, it still wouldn't run. can you explain what you did to get the game running? i was able to get it to run using C+ option but not with Blueprint
