Unreal project crashes because cannot find RLPlugin
Posted By jcforsy 6 Years Ago
jcforsy
jcforsy
Junior Member (196 reputation)Junior Member (196 reputation)Junior Member (196 reputation)Junior Member (196 reputation)Junior Member (196 reputation)Junior Member (196 reputation)Junior Member (196 reputation)Junior Member (196 reputation)Junior Member (196 reputation)
Last Active: 6 Years Ago
Posts: 2, Visits: 69
I have a project I have built using character and animation from IClone.  The project runs in preview fine, but after packaging the project, when I try to open it, the application crashes and in the log, there is the message below
LogPluginManager: Error: Unable to load plugin 'RLPlugin'. Aborting.
LogCore: Engine exit requested (reason: EngineExit() was called)
LogExit: Preparing to exit.
I have moved the files for the CC3 Iclone plugin into the project folder, and within Unreal, the CC3 Iclone plugin shows as being enabled
jcforsy
jcforsy
Found the problem.  I need to have the RLPlugin disabled when I build the Unreal Engine project...
hakzolot
hakzolot
Junior Member (168 reputation)Junior Member (168 reputation)Junior Member (168 reputation)Junior Member (168 reputation)Junior Member (168 reputation)Junior Member (168 reputation)Junior Member (168 reputation)Junior Member (168 reputation)Junior Member (168 reputation)
Posts: 6, Visits: 31
what do you mean by you disabled the RLPlugin? when I disabled it, it still wouldn't run. can you explain what you did to get the game running?
i was able to get it to run using C+ option but not with Blueprint
