Conten inside iC7, possible to sort into own folders?
Posted By AlbinosGambit 5 Years Ago
Posts: 15.8K, Visits: 31.4K
Be mindful that Smart Gallery currently expects things to be in the place where they were installed initially. Otherwise, if you select "Show in Smart Gallery" for an item in the Content Manager, it will not be found.
RL has mentioned an update to Smart Gallery that allows custom folders, but we're not there yet.
The problem is that when the Market Place was created, no rules were in place regarding naming and location, except that a prop needed to by under Props, for example.
There were also no checks on the uniqueness of names. So I have characters from the talented Wil Veeke, where Avatar1, for example,  is either a dog or a girl..:P As, according to Smart Gallery, they both need to be installed in the same location, Smart Gallery only displays one.
Wil Veeke may actually have made a distinction in location, but that got lost with the transfer to Smart Gallery.
Result: I have an enormous number of characters and even more props that are lumped directly under Character or Props that used to be in unique subfolders.
AlbinosGambit
AlbinosGambit
Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)Veteran Member (910 reputation)
Posts: 162, Visits: 478
Hi, so its better t just leave it alone until the update of the smart gallery.
So, how do you guys find what you want when you are not sure where to look?
Also, someone who knows when you buy or get free content from marketplace or content store if the "shop" knows if you have bought it before so you don't get doubles?
I know DAZ store has a good solution for this problem because it only lists the items you don't have from before. That way if you check for do not show items you already own, you will not buy items you already have. Does Reallusion have this?
animagic (4/13/2020)
WIN 10, COOLERMASTER MASTERCASE 500H, MSI GAMING PRO CARBON X470 RGB, AMD Ryzen 7 2700X CPU, MSI GeForce GTX 1650 GAMING X - 4GB GDDR5 RAM GPU, Corsair Vengeance RGB PRO DDR4 3200MHz 16GB RAM, SSD M.2 Corsair Force Series MP510 480 GB, SEAGATE BARRACUDA 3.5 HDD 4 TB.
Best regards
Albin
(AlbinosGambit)
