vrsquare
vrsquare
Visits: 98
Did this happen to you? Just click on Send to iColne button, go to iClone and export as FBX. You'll get the message that gives you the link to get the license.
Posts: 23.1K,
Visits: 36.6K
If your character is using content from purchased content packs, do ensure that you have an export license for each item. This includes characters, clothing, textures, accessories and motions.
doithuong.vn1
doithuong.vn1
Last Active: 6 Years Ago
Visits: 7
Hello, I have the same error as you, you have solved it yet?
Posts: 23.1K,
Visits: 36.6K
Please see my previous answer. It is likely the same issue that you don't have an export license for an item of content.
trothman
trothman
Visits: 82
I just purchased all export licenses and I still receive the same error. After purchasing export licenses, I clicked the refresh button in Smart Gallery but it didnt pick up that I now have the export license. Please advise how I would fix this.
Thank you!
Posts: 23.1K,
Visits: 36.6K
Hi... In Character Creator 3 with your character open, try going to Help > Activate Purchased Items (or Activate Entire Library). This should update the content with the current licensing information. If you still have problems, please contact Technical Support using the link below and they will be able to check the content is correctly activated. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html
tazoskangeli911
tazoskangeli911
Visits: 25
same problem here
Posts: 5.7K,
tazoskangeli911 (7/16/2021) same problem hereDid you follow the steps already mentioned here by Peter(RL) to solve the issue?
Peaches Chrenko
Peaches Chrenko
Visits: 1.4K
Peter (RL) (3/30/2020)
Hi... In Character Creator 3 with your character open, try going to Help > Activate Purchased Items (or Activate Entire Library). This should update the content with the current licensing information. If you still have problems, please contact Technical Support using the link below and they will be able to check the content is correctly activated. https://www.reallusion.com/CustomerSupport/UserEx/QForm.html :) :D :) Jan 27 2023 ...I just had this same problem and this solved it! Thx
_____________________________________________________________________________________________
_____________________________________________ iBUYPOWER Phantom Gamer WA502i Desktop PC: Win 10 64bit - Nvidia GTX 1060 6GB, 24GB RAM (max 32 GB) - Intel Skylake Core i5-6600K Quad-Core Processor - 3.50 GHz, (Max Turbo Speed of 3.90 GHz), Int HD 1TB & WD 1TB Int HD
heybooboo87
heybooboo87
Visits: 5
Hi, in case anyone is till struggling with this, you don't need to buy the license if you already have it. What you need to do is go to Help and scroll down to Active All Libraries. Then restart the software.
