CC3 - The avatar file requires an export license
https://forum.reallusion.com/Topic438497.aspx
Print Topic | Close Window
By vrsquare - 6 Years Ago
Did this happen to you?
Just click on Send to iColne button, go to iClone and export as FBX. You'll get the message that  gives you the link to get the license.
https://forum.reallusion.com/uploads/images/8f2f2e5e-d8a8-4a8a-bb62-4bb2.png
By Peter (RL) - 6 Years Ago
If your character is using content from purchased content packs, do ensure that you have an export license for each item. This includes characters, clothing, textures, accessories and motions.
By doithuong.vn1 - 6 Years Ago
Hello, I have the same error as you, you have solved it yet?
Please see my previous answer. It is likely the same issue that you don't have an export license for an item of content.
By trothman - 6 Years Ago
I just purchased all export licenses and I still receive the same error.  After purchasing export licenses, I clicked the refresh button in Smart Gallery but it didnt pick up that I now have the export license.  Please advise how I would fix this.
Thank you!
Hi...
In Character Creator 3 with your character open, try going to Help > Activate Purchased Items (or Activate Entire Library). This should update the content with the current licensing information.
If you still have problems, please contact Technical Support using the link below and they will be able to check the content is correctly activated.
By tazoskangeli911 - 5 Years Ago
same problem here
By wires - 5 Years Ago
tazoskangeli911 (7/16/2021)
same problem here
Did you follow the steps already mentioned here by Peter(RL) to solve the issue?
By Peaches Chrenko - 3 Years Ago
Peter (RL) (3/30/2020)
Hi...
:) :D :) Jan 27 2023 ...I just had this same problem and this solved it! Thx
