props disappearing in Iray rendering
Posted By Amper Sand 5 Years Ago
Amper Sand
Amper Sand
Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)Distinguished Member (5.3K reputation)
Posts: 731, Visits: 5.2K
Sorry for late reply.
I tried to figure out what's distinctive for those props and here's what I found:
- why apples and bottles (PBR) disappear:
well, they all have Opacity map but this seems to be identical with their Base Color map. If I've turned Opacity's Strength to zero, they become visible.
Strictly speaking, to me it makes sense and I cannot see anything wrong in this since, as far as I know, Opacity is interpreted generally by its black level - and is possible Iray is interpreting in white level (there is no white there, only various colors plus black background)
- why the briefcase (PBR) glows
well, it has a Glow map :) - turning Glow's Strength to zero, it looks normal
I don't know how much of these makes sense to you, but this is what I've found :)
______________________________________________________________________________
Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend
In progress: Black Mamba
AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
Last Active: 3 minutes ago
Posts: 5.3K, Visits: 16.8K
animagic (3/13/2020)
What you also need to be aware of is that, whereas IBL in iClone doesn't cast shadows, it does so in Iray. In fact, anything that emits light will give a shadow (if I remember correctly). So indoor scenes that look OK in iClone may be too dark in Iray.
That is true. As in real life, shadow is dropped from any object if it is in the path of any light source.
I would recommend Iray Sun and Sky for the environment light instead of IBL. It comes natural and it is flexible, as you can set sunlight for any time of the day and any season of the year with appropriate angles.
This is an improvised room with 2 windows and only Iray Sun and Sky as a light source.
https://forum.reallusion.com/uploads/images/5734e203-4ff5-4249-9a96-c42f.jpg
Posts: 15.8K, Visits: 31.4K
Iray does not care about iClone GI settings, nor ambient light. You cannot control bouncing, tracing, shadows, etc.. separately in Iray as we do it *artificially* in iClone.
There is only light amount and light source shape which control those things.
But Iray does care about material emissive settings such as self-illumination and glow maps.
I would check those two for the luggage material(s).
Amper Sand
Amper Sand
https://forum.reallusion.com/uploads/images/842bcfca-77b7-432f-b1d6-d65c.jpg
4u2ges (3/12/2020)
Missing plate is not so bad. I managed to have entire subway cabin disappear
Hahaha, I had a good laugh at work today reading this, it sounds like being said by David Copperfield, lol :)
OK, I attached the two renderings of that frame. I would not call it a slight difference in quality, to me they looks - as I said - like being two totally different systems of lights. And, believe me, there is no torch hidden in that briefcase. I think I know what's happening, but I will check during weekend, I've been very busy at work these days, not too much time for iClone, and I will update this topic. Thanks!
https://forum.reallusion.com/uploads/images/83f48522-6b35-48f1-9298-500f.jpg
sandy-without iray.jpg (116 views, 286.00 KB)
sandy-with iray.jpg (116 views, 119.00 KB)
Missing plate is not so bad. I managed to have entire subway cabin disappear while working on this project
I noticed that while working on it, but did not pay attention as rendering with Iray was not the goal.
Today I figure it was caused by iClone "Consolidate materials" function. All I did, was consolidated 4 glass materials at the time.
Cabin on the right is the default iClone prop. Cabin on the left is customized with 4 glass materials consolidated.
This function is buggy and damage it causes sometimes is irreversible even with Undo function.
https://forum.reallusion.com/uploads/images/034f6fbc-9639-450f-aee1-b3e8.jpg
Amper Sand
Amper Sand
The iProject itself it's 1.5 GB, but I will dig a bit in the weekend to see if I find something and I will attach also the two generated frames.
Thanks!
Posts: 8.2K, Visits: 26.5K
Lord_Dreadmoor (3/10/2020)
Can you post screenshots of the two different renders?
+1
Also consider uploading the iClone project to a file-sharing site (if you're allowed and willing to do that), and I (and probably a couple others) would be happy to take a look at it.
Lord_Dreadmoor
Lord_Dreadmoor
Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)Distinguished Member (2.8K reputation)
Posts: 230, Visits: 2.4K
artstation.com/dreadmoormediaarts
Amper Sand
Amper Sand
Have anybody else encountered this behavior, some props becoming invisible - I mean, literally invisible - when rendered with Iray in iClone7.71/7.72? :)
On my scene I found two cases:
- on a plate I have several apples, all perfectly visible in normal rendering, but when rendered with Iray - the plate has disappeared, apples are "levitating" above the table (as a funny note, I would expect apples to dissappear, no the plate)
- on the same scene, there are also on the table three bottles, from which, on Iray, two are invisible and one barely visible, like being translucent (like HG Wells' Invisible Man)
Apart from this, the overall lighting is absolutely, totally different than in the normal rendering, like there's is a completely different system of light sources - it looks very cool, but is not at all what I wanted or expected.
