Importing Animations from Mixamo
Posted By shadybearbklyn 5 Years Ago
shadybearbklyn
shadybearbklyn
Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)Distinguished Member (2.7K reputation)
Posts: 337, Visits: 2.8K
Should I save animations from Mixamo at 30fps or 60fps? The tutorials state 30fps, but since IClone renders at 60fps I was wondering which would work better.
Posts: 15.8K, Visits: 31.4K
shadybearbklyn (2/28/2020)
30 FPS or even less is fine.
The reason is that you get a keyframe for every frame. By using lower FPS, iClone will interpolate between frames, which may result in smoother movements. An exception would be very fast movements which a lot of detail.
Last Active: 5 days ago
Posts: 8.2K, Visits: 62.6K
My experience is that Mixamo motions are great at 12-15 FPS. As Animagic says, it is the sampling rate of the motion, not the playback rate.
shadybearbklyn
shadybearbklyn
Thanks. I wanted to check before downloading them.
I would go ahead and download therm at the higher rate. 3DXchange has a rate conversion on import. I set the frame rate on import, not download.
