Eric C (RL)
Eric C (RL)
Visits: 6.0K
Dear iCloners, Get ready to implement spring effects into your animations! With our Spring Joints plugin, you can create spring physics for your characters and props in a snap! We have uploaded an awesome trailer, and make sure you watch the FULL VIDEO as we carried out a sophisticated demo. Install for this plug-in is fast and easy! Download it for FREE right now! > Spring Joints Feature: This plug-in allows you to build your physics simulation quick and easy. Start out by building a prop hierarchy by parenting one prop after another. Select the individual props in the chain and load them into the script window. By adjusting the spring parameters, you can adjust the spring joints' stiffness, bounciness, and damping. Let's take a look of the applications below.
Application on Objects:
Setup the hierarchy from a chain of props and simulate the motions (0:24~1:03) Demonstrations of Stiffness, Stiffness Scale, Bounciness, Bounciness Scale and Damping (1:05~3:55)
Application on Characters: (simulating the work movement with )Simulation on bones (4:05~4:50) In this part, we demonstrated how spring physics simulates a flowing hair.
More flexible hierarchy structures (4:52~6:42)
Spring physics can simulate passengers on a bumpy ride! Take a closer look at our step-by-step tutorial and learn how to adjust the spring parameters.
Explore our wiki page and find out how we create this with Python!
