Live Face not connecting to Iphone X. Please help
Posted By JetBlaque 6 Years Ago
JetBlaque
JetBlaque
Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)Veteran Member (648 reputation)
Posts: 18, Visits: 72
I keep getting the message "Failed To Connect To Live Face" when trying to connect iphone and PC to use Live Face. I used the "1. Facial Demo. iProject" and I also tried loading the Christian character when trying to connect the phone to the app.
  1. - I have installed the software and plugins and used the hub to update the programs.
  2. - I have made sure the iphone and the PC are on the same network.- I have made sure the iphone and the PC have the same IP address.
  3. - I have restarted the Program.
  4. - I have restarted the PC.
  5. - Note: The Iphone X is without Cellular Service. I just purchased the phone for the camera.
  6. - Please help!
  7. - Please let me know if there is anything else I need to do.
  8. - Thank youhttps://forum.reallusion.com/uploads/images/aadc31ae-242a-4db5-903b-6df5.jpg
AllenLee (RL)
AllenLee (RL)
Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)Senior Member (343 reputation)
Posts: 54, Visits: 541
Hi thejetshowlive,
You need to add the port number after IP address.
like this: (192.168.1.23:999)
999 is the default port number of LIVEFace.
Allen Lee
kahmry
kahmry
New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)New Member (43 reputation)
Last Active: 6 Years Ago
Posts: 2, Visits: 5
Hi there.. I have the same problem & did everything also insert the port 999, I tried mostly all the possibilities, can't connect...
But the PC cam i can connect by faceware realtime,
my decision to by this prodcut depends on this, otherwise I will try to find other software..
Than you
Xeo
Xeo
Senior Member (335 reputation)Senior Member (335 reputation)Senior Member (335 reputation)Senior Member (335 reputation)Senior Member (335 reputation)Senior Member (335 reputation)Senior Member (335 reputation)Senior Member (335 reputation)Senior Member (335 reputation)
Posts: 4, Visits: 91
I have also done everything that Senior Member , JET BLACK has done, but mine doesn't even see the iPhone to place the IP address in the field. When I click the tab for the IP address to go into the field, nothing happens. PLEASE HELP!
Posts: 9.2K, Visits: 22.1K
Best bet is to use an ethernet adapter and cable to connect - USB/wi-fi can be a bit finicky whereas ethernet ALWAYS works easily.
Posts: 15.8K, Visits: 31.4K
Kelleytoons (5/29/2022)
Also, when you use a wired ethernet connection, make sure to disable wireless in the iPhone settings. I sometimes forget and then things don't work.
