UE4 cannot select any other Shader besides "Standard Shader" on Auto Setup Import options.
Posted By umarb8 5 Years Ago
UE4 cannot select any other Shader besides "Standard Shader" on Auto...
umarb8
umarb8
Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)Junior Member (224 reputation)
Posts: 2, Visits: 32
Can no longer select any other Shader besides "Standard Shader" on Auto Setup Import options. This is the case for me with all FBX models exported from CC3. I even reimported older characters that I was able to use the HQ shader on before, but the option is no longer available. How do I "re-enable" the ability to use the HQ Shader.
UE4 23.1
CC 3.21
Auto_Setup_1.02 and tried with 1.03
https://forum.reallusion.com/uploads/images/292519e7-1df4-470b-a73f-7594.png
unit23
unit23
Posts: 115, Visits: 380
umarb8 (1/13/2020)
Can no longer select any other Shader besides "Standard Shader" on Auto Setup Import options. This is the case for me with all FBX models exported from CC3. ..Auto_Setup_1.02 and tried with 1.03
1.03 was released January 15th I believe, so it is unclear what other version you tested. So perhaps give the new 1.03 AutoSetup version another pitch? Make sure that the folders are copied to your Unreal project as outlined in the documentation  https://manual.reallusion.com/CC_and_IC_Auto_Setup_Plugin/ENU/CC_and_iC_Auto_Setup/1.0/02_for_Unreal/Installing_CC_Auto_Setup_to_Unreal_v4.htm
Miranda (RL)
Miranda (RL)
Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)Distinguished Member (68.7K reputation)
Posts: 1.8K, Visits: 11.2K
Hello,
Do you put the CC_Shaders folder under the Unreal Content folder?
The options of other shader types will be unavailable if you didn't do so.
