GIM
Last Active: 4 Months Ago
Visits: 7.4K
Just a note: The forum search is useless! Results are shown with 1 post for each item found, not whole thread. When adding Natalie to a bare project and pressing play, there is a hair and dress bounce regardless of where the play head is....what is the purpose of this and how to get rid of it? Thanx, MT
Posts: 5.7K,
Both the Hair and Dress have Physics applied to provide them with natural looking motions when moving. The short bounce/fall is caused by the physics being activated when "Play" is pressed. You can turn the Physics off in the "Modify" panel - the Hair and Dress need to be selected separately to ensure that the Physics panel is active for each. With Physics active it's best to ensure that any "action" in a scene really starts a few frames after Play is pressed. The few frames showing the Physics being activated can then be edited out when the video is rendered.
james_muia
james_muia
Visits: 1.3K
Physics and effects such as fire, etc. have a bit of a natural start up time so it takes a certain amount of frames before they are properly working. As a word of advice, never start your scenes on frame 1, start them on like frame 250 so it gives you enough time for the effects to get started.
IMDB: James Muia Aviticus Dragon on YouTube
Computer Specs: Intel® Core™ i7-7820X Processor (8x 4.30GHz/11MB L3 Cache) Corsair Hydro Series H115i 280mm Liquid CPU CoolerASUS ROG STRIX X299-E Gaming Motherboard 32 GB DDR4-3200 GSKILL Ripjaws V Memory NVIDIA GeForce GTX 1080 Ti - 11GB - EVGA FTW3
Snarp Farkle
Snarp Farkle
Visits: 3.6K
Hi mt900, That bounciness is the Physics Engine kicking in and it will happen at the beginning of any project that has soft cloth enabled hair or clothing. It will also happen each time you pause then restart playback of your animations, or have a large gap between clips without the proper transition curve preset Proper "Weight Mapping" of the hair or clothing items will get rid of the bounciness, that's something that just takes time to fuss with and I am by no means an expert on weight mapping, I just watch YouTube videos, check the forum and refer back to the online manual on the subject, and try different settings I find there. Searching the forum can be daunting at times, I use the advance search feature "Using EXACT match" to whittle down the number of responses. Hope this helped.
GIM
Visits: 7.4K
Thanx to all who applied as the Physix part makes sense but the implementation of it doesn't. Another quick question....is there a way to either move or hide the various control gizmos? If hiding them, are they key controls to replace the gizmo movements? The lighting ones are especially annoying as they pop up right in the middle of the scene. Thanx again, MT
dante1st
dante1st
Visits: 2.3K
I just wanted to say I 100% agree about the search function. I always use it too before asking my question, but they show individual posts one by one, rendering it close to useless.
My iClone short films: https://www.youtube.com/iClone316
Posts: 5.7K,
mt900 (12/26/2019) Thanx to all who applied as the Physix part makes sense but the implementation of it doesn't. Another quick question....is there a way to either move or hide the various control gizmos? If hiding them, are they key controls to replace the gizmo movements? The lighting ones are especially annoying as they pop up right in the middle of the scene. Thanx again, MT
You can turn the Gizmos on and off in the Preferences panel, or by using the keyboard shortcuts shown in the image below.  You can view the full list of keyboard shortcuts in this list from the iClone user manual. :) A direct link to the list is also included under the "Help" menu in iClone. :cool:
GIM
Visits: 7.4K
Thanx but that only hides/unhides the rotate/move gizmos and not these (see attached). Regards, MT
Posts: 15.8K,
Visits: 31.4K
The yellow one is the bounding box indicating what is selected. You can't disable that other than by not selecting the object. The red/blue/green item is the world axis, which you can disable in the settings as already mentioned (Ctrl-A). It is important to note that none of these will appear in your final render.
