hhiiffii
hhiiffii
Visits: 892
Has anyone had issues where transport buttons on timeline and undo button cause major lag in response.
doubblesixx
doubblesixx
Last Active: 10 Months Ago
Visits: 474
Never mind.. I thought you meant you left the computer for a while.. Not having iCLone in the background while you worked on other things... I have had problems like that but when leaving the computer for a while
This is a silent signature
Posts: 15.8K,
Visits: 31.4K
Back to actual issues. I have had occasional hangs, where I do something and iClone becomes unresponsive. It was difficult to find a pattern, but it seems to occur when I leave iClone open for a while without any user actions (while I do something unrelated) and then after coming back to iClone doing an Undo or some other action related to the timeline (I think it involves mostly the timeline). It seems that in that case iClone has trouble updating the undo repository in temp and then just hangs. I have moved the temp folder to another disk but that didn't make a difference. This is not related to any specific project, except the projects are fairly large (around 1 GB on disk).
Amper Sand
Amper Sand
Visits: 5.2K
pupkin96vasya (5/7/2020) iclone facial mocap ipad ? And whether there is an example of this or an instruction or video.Your iPad should provide TrueDepth camera in order for Reallusion's Live Face app (available on AppStore) to work. And here is a good tutorial: https://www.youtube.com/watch?v=UHy47q83pr0
______________________________________________________________________________ Software developer. iClone hobbyist since January 11, 2020. Best work so far: Robots among us: The Lab and The sad end of a legend In progress: Black Mamba AMD Ryzen 3950X 16C/32T 4.2 GHz, 64GB RAM, RTX2080 11GB, 2TB Samsung 970 Pro SSD, 8TB Seagate BarraCuda HDD, Win11 64-bit, iClone 8.12
pupkin96vasya
pupkin96vasya
Visits: 72
Posts: 23.1K,
Visits: 36.6K
pupkin96vasya (5/4/2020) Thank you for your answers. Please tell me if I can first animate a character using Kinect, and then animate the iphone and leap motion on top of it.Yes you can do that. Any recorded Kinect mocap can be saved and then used with Motion LIVE 3D recorded facial capture.
pupkin96vasya
pupkin96vasya
Visits: 72
Last Active: 11 days ago
Posts: 5.3K,
Visits: 16.8K
When using Orthogonal camera, switching to Bottom view (from Views menu - there is no shortcut) and then using Orbit tool (C), the scene is randomly becoming overwhelmed with Directional light under certain angles. To restore the scene you have to switch to some other View Mode (A, S, D, F, G). I believe someone has reported similar incident, when the scene turns shiny white. As I said, it is hard to catch, but for me it only happens with Orthogonal Camera > Bottom View > Orbit Tool Scene intensity does not matter, it could be a complex scene on just one avatar.
Posts: 23.1K,
Visits: 36.6K
pupkin96vasya (4/26/2020) Здравствуйте можно ли использовать , iphone ( для анимации лица). и прыжок движения ( для анимации рук) в то же время ? Yes you can use both Live Face (iPhone) and Leap Motion at the same time with the Motion LIVE 3D plugin.
pupkin96vasya
pupkin96vasya
Visits: 72
