So I've never noticed this before and maybe it's always been true (or, more hopefully, I'm doing something wrong) but I can't get the face to respect any opacity map I put there. Not even when I transfer the CC3 character to iClone. I'm out the door for tennis so I need to test this further with body textures but... wtf? I put a (mostly) black map there and it acts like it's all white (which does the same thing -- and a mixed map shows no opacity, anywhere). What am I doing wrong?
raxel_67
raxel_67
Group: Banned Members
Visits: 2.0K
I don't think you are doing anything wrong, do opacity maps work at all on anything?
Unless your opacity slider is at zero or opacity is disabled in preferences
Scyra
Visits: 2.5K
Just tested; works fine for me. Black is transparency, white is opaque. Strength needs to be turned up to get any effect. Copy & Paste one of your black Metallic maps into the Opacity slot—the whole face should disappear. If you still can't get it working, ask Mike K...oh wait...
5 Years Ago by
Scyra
Crap -- this is one of those things I knew and forgot (I hate to sound like an ass, but often times I've forgotten more things than a lot of people know). PNG files won't work in opacity slots. Again, I knew this but forgot it. It's a weird bug that iClone really ought to fix but it's okay as long as I remember it. (And your line about asking Mike K. -- I used to work support at Autodesk for Max, the same way Rampa does here, on a consultant basis. I had an issue one time and I asked various tech folks and they said they'd get back to me. Eventually one day I got a call from another dev who asked me about the same problem. I told him that was an amazing coincidence, as that was exactly the problem I was trying to find an answer for. Turns out he was trying to solve my problem -- someone had asked HIM and he said to himself, "Hey, Mike K will know" and asked me. So the problem got chased back to me to solve. Which I eventually did :> .
Posts: 15.7K,
Visits: 30.6K
Mike, I was just about to ask if it was perhaps a PNG image, but you did solve your own problem! EDIT: Corrected grammar/typo...
5 Years Ago by
Scyra
Visits: 2.5K
That's a good one. More than a few times I've gone searching for solutions only to find a years old forum post with the answer...authored by me! Thanks for the tip about PNG's. I've been using them 90% of the time so I'd have run into the same issue soon enough
Job -- I wish you had chimed in sooner. What I hate most about getting old is just not remembering all I used to know. As soon as the others here said it worked for them and just to try some opacity maps I instantly remembered what was wrong. (Now, really, we ought to get the PNG problem solved. It's stupid that it doesn't work and what's really scary is that a year or two from now I'll forget this again).
BlueyCreative
BlueyCreative
Visits: 2.8K
Put a note in your Account settings (Notes section) so you wont need to search for the answer in 2 years time lol
Bluey Creative in the Marketplace
Last Active: 23 minutes ago
Posts: 5.0K,
Visits: 15.9K
For opacity maps I use nothing but PNG to get a clean, noise free cut outs. Just make sure to save your PNG images with 24 bit depth, because as you have learned 32 bit does not work.
5 Years Ago by
Unfortunately the default in Photoshop for a quick output to PNG is 32 (and I see no way to change this, but I'll dig around on the Adobe forums). This is the mode I use ALL the time and it would be difficult to break me out of it (luckily I seldom use opacity maps).
