Character Creator 3 Collision Shapes?
Posted By Neole F 5 Years Ago
Neole F
Neole F
Veteran Member (662 reputation)Veteran Member (662 reputation)Veteran Member (662 reputation)Veteran Member (662 reputation)Veteran Member (662 reputation)Veteran Member (662 reputation)Veteran Member (662 reputation)Veteran Member (662 reputation)Veteran Member (662 reputation)
Posts: 89, Visits: 337
Thanks! The Christian Natalie loading idea is good. You are correct the collision shapes are retained in cc3. I also just noticed a load collision shapes icon in cc3 haven't checked it out yet.
Last Active: 11 hours ago
Posts: 15.8K, Visits: 31.3K
Collision shapes are not used in CC, but they should be exported with the character when you save it as an iAvatar or send the character to iClone.
You can then view and modify the collision shapes in iClone.
Now for some reason, there is a problem with collision shapes for CC characters. I have reported this in Feedback Tracker as issue #5392.
This has been partially fixed, but the most complete set of collision shapes for CC characters are those for the Christian (male) and Natalie (female) characters, which can be reused for other CC characters.
The screen capture below illustrates the steps for Natalie, which you would use for female CC characters:
https://forum.reallusion.com/uploads/images/04a505db-b97f-4f8e-b839-394d.png
So once saved, the set of collision shapes can be applied to another CC character by loading the saved set.
There is a "bug" in iClone that causes a newly selected collision shape not to be highlighted (FT issue #6238). As a workaround you need to uncheck "Reduce Idle Load" in Preference under Real-time Render Options.
https://forum.reallusion.com/uploads/images/5a65245f-ba9b-4ce8-a07c-9f23.png
As far as I know collision shapes are retained when importing into CC.
Neole F
Neole F
I cannot find Collision Shapes in Character Creator 3. So for proper Physix and soft clothes I have to modify the collision shapes in iClone. Is that an oversight or is there a reason for this?
Also are collision shapes modified in iClone retained if the character is imported in CC3 and then clothed with different clothes and exported as iAvatar?
