FallenNInja
FallenNInja
Visits: 1.4K
Specs: 9700k at 5ghz 2080TI FE 32gb of ram Windows 10 Working monitor: Acer 4k60 G-Sync.
Notes: All drivers, system and Reallusion updates are installed. CPU Usage ramps up to 100% GPU hovers around 4%-16%
Issue: I have noticed that even on an empty project I only get about 22fps while moving around in the viewport. After loading up a character that's about 10k triangles and creating a static 90k triangle scene with no lighting or AO with the preset set to high I only get a bout 2-8 fps.
This makes the using the viewport very clumsy and difficult. I was wondering if its normal to have such low performance and or if there is anything that I can do other than changing the graphics preset that barely helps.
