Hello Wildstar,
Hey Icloner
First of all, we would like to thank you, Wildstar, for your confidence in us. Of course, it is and will remain your model and work! :-)
Our idea behind it is to fuel each other with sophisticated techniques, special tricks or simply experimental procedures.
As a media design company, we are extremely careful with the right to own work :-) So do not worry, it will only be used internally here ;-)
Enclosed you will find our ideas and techniques to give the output files of Iclone the highest quality.
All images were calculated to 100% in Iclone (unless it is something else in the picture) There were no subsequent work done via external image processing software.
Hope you enjoy our works & ideas and inspire other users to participate in sharing your techniques and ideas.
The reflection is created by a simple tarp with a few pixels distance to the window frame from the outside. The IES-Light is the last update the images to fine nuances more realistic and provides more mood.
Set NPR filter to 6 to get a microfine borderline on all objects barely visible but very effective in image quality.
Emissive Lights a very cool effect and in the indirect lighting in the solid component.
All other values in the settings are limited to the best possible output. Here are some of the issues of Indigo (the plugin version of Iclone) and the rendered IRay version (also plugin for Iclone).
As far as our submission ...
